Target Mac: 19.0.0 Darwin Kernel Version 19.0.0: Thu Oct 17 16:17:15 PDT 2019; root:xnu-6153.41.3~29/RELEASE_X86_64 x86_64
1) I Installed the latest Intel® Optimization for TensorFlow* from Anaconda* Cloud successfully "conda install tensorflow"
2) but the proposed sanity check
python -c "import tensorflow; print(tensorflow.pywrap_tensorflow.IsMklEnabled())"
failed with
File "<string>", line 1, in <module>
AttributeError: module 'tensorflow' has no attribute 'pywrap_tensorflow'
链接已复制
Could you please check the tensorflow version installed by using the command
python -c "import tensorflow; print(tensorflow.__version__)"
If it is tensorflow 2.0.0(latest version), please try to install stable tensorflow version 1.14.0 by uninstalling the current version.
conda uninstall tensorflow
Please follow the below commands to install intel-optimized-tensoflow from anaconda channel
conda create -n tf-conda python=3.6
conda install tensorflow==1.14.0 -c anaconda
If you still faces any issue, please feel free to get back to us.
Hey Gert,
Could you please confirm whether you are facing the same issue with tensorflow version 1.14.0
[ Run this command to check it: python -c "import tensorflow; print(tensorflow.pywrap_tensorflow.IsMklEnabled())" ]
Actually, this error is due to the tensorflow's version change to 2.0 has changed the tensorflow API structure significantly.
If you are planning to use tensorflow 2.0.0 in future, to check if MKL-DNN is enabled ( in tensorflow 2.0.0 ) , please use the below command(instead of the sanity check command in your answer)
python -c "from tensorflow.python import pywrap_tensorflow; print(pywrap_tensorflow.IsMklEnabled())"
you may not face this issue in earlier versions of tensorflow upto tensorflow 1.14.0
Hi Chitra,
Yes I got ''True'
at the end of a long tail of "FutureWarning"
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint8 = np.dtype([("qint8", np.int8, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint16 = np.dtype([("qint16", np.int16, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint32 = np.dtype([("qint32", np.int32, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
np_resource = np.dtype([("resource", np.ubyte, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
True
