1-Shift PRBS
명예로운 기여자 II
1,783 조회수
I have reading a lot of posts that they are talking about shift registers, but always they are refered to a fix data, not to PRBS. What I would like to get is from a PRBS generator (can be the qsys block or created in quartus), delay one bit the PRBS sequence and after that add the two sequences (PRBS + PRBS shifted). As an example, if the original sequence is 1010, I would shift one bit right: 0101 and finally I would sum both sequences (1010 + 0101). Is it possible to do this for a PRBS code?
I have though in some options, but I don't know if they will work or if there is a faster option:
1. Store the original PRBS in a RAM and then work from there.
2. Connect the PRBS generator to a shift register (Megawizard).
Any help will be appreciate it.
Thanks!!!
0 포인트
9 응답
명예로운 기여자 II
1,119 조회수
--- Quote Start ---
Thanks!!!
--- Quote End ---
if I understood you:
--clocked process if reset then shift1 <= "1010"; elsif rising_edge(clk) then shift1 <= shift1(0) & shift(3 downto 1); shift1_d <= shift1; result <= std_logic_vector(signed(shift1) + signed(shift1_d)); end if;
0 포인트
명예로운 기여자 II
1,119 조회수
That was an example with a fix data, but my real data come from a PRBS sequence, that means a random sequence that comes from an alghoritm: This is my problem... Any idea???
By the way, thank you very much for your quick answer ;)
0 포인트
명예로운 기여자 II
1,119 조회수
It can come from anywhere. same applies.
get your prbs data then assign it to shift1 per update (instead of reset) and go from there. The update needs to be slower if you want to shift shift1 all around.
0 포인트
명예로운 기여자 II
1,119 조회수
Read this tutorial on LFSRs and PRBSs
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip
and use the code.
I'm not sure why you would want to shift-and-add PRBS sequences. Perhaps you can explain your requirements? Or perhaps after reading this tutorial you will have a better idea of what it is you really want.
Cheers,
Dave
0 포인트
명예로운 기여자 II
1,119 조회수
Thank you very much for the replies,
I need to do this in order to get duobinary modulations from the signal transmit from transceivers. In this case I would need transmit the sequence achieved after the sum of PRBS sequence + PRBS shifted.
Cheers
0 포인트
명예로운 기여자 II
1,119 조회수
--- Quote Start ---
--- Quote End ---
Are you using actual *transceivers*? In that case, you cannot perform the shift-and-add in the time domain of the transceiver, you have to perform it in the parallel domain of the FPGA fabric. If you read the tutorial at the link I posted, it shows how to create multiple bits out of a PRBS in one FPGA fabric clock period. You would use that, along with your shift-and-add logic, and then send the result to the transceiver.
Cheers,
Dave
0 포인트
명예로운 기여자 II
1,119 조회수
Exactly Dave, I am using transceivers! I am reading the tutorial right now.
Thank you for your help! ;)
0 포인트
명예로운 기여자 II
1,119 조회수
--- Quote Start ---
--- Quote End ---
Ok, so am I, but I am using the PRBS to modulate signals across an AC-link. See the details here:
http://www.ovro.caltech.edu/~dwh/wbsddc/hittite_adc_hw.pdf
--- Quote Start ---
--- Quote End ---
You're welcome. Good luck!
Cheers,
Dave
0 포인트
명예로운 기여자 II
1,119 조회수
What PRBS pattern you wish to use?
0 포인트
응답
