17255 Discussions
10AS027E3F29I2SG simulation error
EDing
Partner
#   Time: 0 ps Iteration: 0 Instance: /bsm_epl_pcl_egl_bsf_tst/uut/b2v_inst File: /build/swbuild/SJ/nightly/18.0std/614/l64/work/modelsim/eda/sim_lib/altera_mf.v
# ** Error: (vsim-3935) ../../BSM_EPL_PCL_EGL.vhd(1316): Port 'A_OUT' not found in the connected module.
# ** Error: (vsim-3935) ../../BSM_EPL_PCL_EGL.vhd(1316): Port 'A_IN' not found in the connected module.
EDing
Partner
What's missing here to set up the simulation with Qsys IP? Thanks!​
MuhammadAr_U_Intel
Which IP are you trying to simulate ?
Can you share some more details, what are the steps you have followed to bring up simulation ?
Intel FPGA IP's comes with auto-generate script located in directory <ip name>/simulation/ that can be used to bring up the simulation.
https://www.intel.com/content/www/us/en/programmable/documentation/mwh1409960636914.html#mwh1409958298944
Let me know if you are able to proceed with this.
Arslan
EDing
Partner
Hi Arslan,
Glad to see your answer here! Thanks! Attached is the log file, could you tell what's missing from the log please?
Best,
Ellen
MuhammadAr_U_Intel
Hi Ellen,
I am looking at the log file, it is hard to pin point the exact issue. As I can see a couple of IP's been compiled in the design.
Is it possible to share the design in a private message may be to take a further look ?
Or you can point me what IP was instantiated at line number pointed in Error message.
Also can you confirm if IP is generated in verilog or vhdl ?
Arslan
EDing
Partner
Hi Arslan! I have opened a case 00398071, it would be great if you can help identify the problem. Thanks!​
MuhammadAr_U_Intel
Hi Ellen, I have taken a look at the design, please add the following lines to you “BSM_EPL_PCL_EGL.vhd” file --edits for simulation library altera_mf; use altera_mf.all; library altera; use altera.all; Let me know if you are able to proceed with this. Thanks, Regards, Arslan
EDing
Partner
Thumbs up to you again, Arslan!​
MuhammadAr_U_Intel
Glad to know you are able to proceed with the suggested workaround.
Arslan
