17249 Discussions
2D array with different number of elements
Is it possible to have this array in VHDL?
[i][j] =
[1][sample1, sample2, sample3]
[2][sample1, sample2, sample3, sample4, sample5]
[3][sample1, sample2]
It seems like [j] dimension has to be a fixed value.
--- Quote Start ---
--- Quote End ---
No.
You could use an array if you changed your format
[i][j] =
[1][numvalid, sample1, sample2, sample3, 0 , 0 ]
[2][numvalid, sample1, sample2, sample3, sample4, sample5]
[3][numvalid, sample1, sample2, 0 , 0 , 0 ]
or you can use a list of lists (or an array of lists).
You'll have to be careful if you're using this for synthesis though.
Cheers,
Dave
i and j have to be a fixed value when you instantiate the signal or variable, as with any language.
Actually, in Matlab you can have any combination of dimensionality for j. Would Verilog be better at this?
not really, it all comes down to what is synthesisable, not about which language is better at arrays.
