I am new to Verilog and I am trying to implement a 32-bit adder Carry Look-ahead, but the output is incorrect. I included the simulation in ModelSim and my verilog code. https://www.alteraforum.com/forum/attachment.php?attachmentid=10447module adder(CarryIn, a, b, result, CarryOut);
input a, b;
input CarryIn;
output CarryOut;
output result;
parameter delay = 50;
wire p, g;
wire c;
buf# (delay) buf0(c, CarryIn);
genvar i;
generate
for(i=0; i<32; i++)
begin: CalculatePandG
and# (delay) myAnd(g, a, b);
or # (delay) myOr(p, a, b);
end
endgenerate
carry_lookahead myCarryLookAhead(p, g, CarryIn, c, CarryOut);
genvar j;
generate
for(j=0; j<32; j++)
begin: JoinedAdder
xor# (delay) Adderj(result, c, a, b);
end
endgenerate
endmodule
//CARRY-LOOKAHEAD
module carry_lookahead(p, g, CarryIn, c, CarryOut);
input p, g;
input CarryIn;
output c;
output CarryOut;
buf# 50 buf0(c, CarryIn);
genvar i;
generate
for(i=0; i<31; i++)
begin: CarryLookAhead
cal_carry myCarry(p, g, c, c);
end
endgenerate
cal_carry myCarry31(p, g, c, CarryOut);
endmodule
module cal_carry(p, g, cin, cout);
input p, g, cin;
output cout;
wire temp;
and# (delay) and0(temp, p, c);
or # (delay) or0(cout, temp, g);
endmodule
Could someone help me to fix this problem? Sorry for my bad English! Thanks in advance.
链接已复制
6 回复数
Hey,
i was looking for a similar code and i actually found this. i think it's a good idea to combine 4-bit-adders to get the 32-bit-input as required. http://verilog-code.blogspot.com/p/types-of-adders-with-code.html You'll probably need to change the code slightly to implement into your design. but it's a pretty good reference! hope this is helpful to you. thanks.hie v1t0ry,
sure, no problem. could i suggest that you: a) upload your fixed code here? if it's not confidential, then it would be really helpful as well for other forum members if they happen to have the same problem and stumble across your code? =) b) also, if not confidential, upload a copy of the fixed / working code in the Share Materials section of the forum? http://www.alteraforum.com/forum/forumdisplay.php?f=16 just my 2 cents, to help each other out! take care and have a nice day!This is my Verilog code of MIPS 32-bit ALU, which is able to perform 4 functions including addition, subtraction, exclusive-OR, and set-on-less-than.
I use the adder to perform both addition and subtraction. Hope it is useful for amateurs like me! :)
`timescale 1 ps / 100 fs
// DA Cau Truc May Tinh - Lab 2 - ALU
// Ngo Dat - 11DT3
//32-BIT ALU
module alu(Output, Carryout, Zero, Overflow, Negative, BusA, BusB, ALUControl);
output Output;
output Carryout, Zero, Overflow, Negative;
input BusA, BusB;
input ALUControl;
wire c, Less, add_out, xor_out, Less_out, p, g, BusBinv;
wire CarryIn;
assign Less = 31'd0;
buf# (delay) buf0(CarryIn, ALUControl);
genvar k;
generate
for(k=0; k<32; k++)
xor# (delay) myXor(BusBinv, BusB, ALUControl);
and# (delay) myAnd(g, BusA, BusBinv);
or # (delay) myOr(p, BusA, BusBinv);
end
endgenerate
carry_lookahead myCarryLookAhead(p, g, CarryIn, c, Carryout);
genvar i;
generate
for(i=0; i<32; i=i+1)
begin: JoinedALUs
alu_1bit myALU(add_out, xor_out, Less_out, BusA, BusB, c, Less, ALUControl);
end
endgenerate
buf# (delay) buf1(Negative, add_out);
xor# (delay) xor0(Overflow, c, Carryout);
xor# (delay) xor1(Less, Overflow, Negative);
Zero_module myZero(Zero, Output);
mux32x4_32 myMUX(Output, add_out, xor_out, add_out, Less_out, ALUControl, ALUControl);
endmodule
//1-BIT ALU
module alu_1bit(add_out, xor_out, Less_out, a, b, CarryIn, Less, ALUControl);
output add_out, xor_out, Less_out;
input a, b, CarryIn, Less;
input ALUControl;
wire bin, btemp;
not# (delay) not0(bin, b);
m2_1 myMUX0(btemp, ALUControl, b, bin);
xor# (delay) myAdder(add_out, a, btemp, CarryIn);
xor# (delay) xor0(xor_out, a, b);
buf# (delay) buf0(Less_out, Less);
endmodule
//CARRY-LOOKAHEAD
input p, g;
input CarryIn;
output c;
output CarryOut;
genvar i;
generate
for(i=0; i<31; i++)
end
endgenerate
endmodule
input p, g, cin;
output cout;
wire temp;
and# (delay) and0(temp, p, cin);
endmodule
//2-1 MULTIPLEXOR
module m2_1(data, sel, y0, y1);
output data;
input sel, y0, y1;
wire nsel, a, b;
not# (delay) not0(nsel, sel);
and# (delay) and0(a, nsel, y0);
and# (delay) and1(b, sel, y1);
or # (delay) or0(data, a, b);
endmodule
//4-1 MULTIPLEXOR
module m4_1(data, sel1, sel0, y0, y1, y2, y3);
output data;
input sel1, sel0, y0, y1, y2, y3;
wire out0, out1;
m2_1 myMultiplexer0(out0, sel0, y0, y1);
m2_1 myMultiplexer1(out1, sel0, y2, y3);
m2_1 myMultiplexer2(data, sel1, out0, out1);
endmodule
//32x4 TO 32 MULTIPLEXOR
module mux32x4_32(Output, Add, Xor, Subtract, SLT, control_1,control_0);
output Output;
input Add, Xor, Subtract, SLT;
input control_1, control_0;
genvar i;
generate
begin : mux32x4_32
m4_1 myMux(Output, control_1, control_0, Add, Xor, Subtract, SLT);
end
endgenerate
endmodule
//ZERO FLAG
module Zero_module(Output,Input);
output Output;
input Input;
wire temp0, temp1, temp2, temp3, temp4, temp5, temp6, temp7, temp8, temp9;
or# (delay) or0(temp0, Input, Input, Input,Input);
or# (delay) or1(temp1, Input, Input, Input,Input);
or# (delay) or2(temp2, Input, Input, Input,Input);
or# (delay) or3(temp3, Input, Input, Input,Input);
or# (delay) or4(temp4, Input, Input, Input,Input);
or# (delay) or5(temp5, Input, Input, Input,Input);
or# (delay) or6(temp6, Input, Input, Input,Input);
or# (delay) or7(temp7, Input, Input, Input,Input);
or# (delay) or8(temp8, temp0, temp1, temp2, temp3);
or# (delay) or9(temp9, temp4, temp5, temp6, temp7);
nor# (delay) nor0(Output, temp8, temp9);
endmodule
// Test bench for ALU file
module ALUStimulus();
parameter ClockDelay = 100000;
reg BusA, BusB;
reg ALUControl;
wire Output;
wire Zero, Overflow, Carryout, Negative;
integer i;
// If your register file module is not named "alu" then you will
// have to change the following line in order to create an instance of
// your register file. Also you must make sure that the port declarations
// match up with the module instance in this stimulus file.
alu alu1(.Output, .Carryout, .Zero, .Overflow, .Negative, .BusA, .BusB, .ALUControl);
initial begin
// Addition unit testing
ALUControl=00;
BusA=32'h00000DEF; BusB=32'h00000ABC;# (ClockDelay); // Should output 000018AB
BusA=32'h00001234; BusB=32'h00000105;# (ClockDelay); // Should output 00001339
BusA=32'h7FFFFFFF; BusB=32'h00000001;# (ClockDelay); // Should output 80000000, overflow, negative
// Xor unit testing
ALUControl=01;
BusA=32'h00000DEF; BusB=32'h00000ABC;# (ClockDelay); // Should output 00000753
BusA=32'h00001234; BusB=32'h00000105;# (ClockDelay); // Should output 00001331
BusA=32'h80000000; BusB=32'h00000001;# (ClockDelay); // Should output 80000001
// Subtraction unit testing
ALUControl=10;
BusA=32'h00000DEF; BusB=32'h00000ABC;# (ClockDelay); // Should output 00000333
BusA=32'h00001234; BusB=32'h00000105;# (ClockDelay); // Should output 0000112F
BusA=32'h80000000; BusB=32'h00000001;# (ClockDelay); // Should output 7FFFFFFF, overflow
// Set Less Than unit testing
ALUControl=11;
BusA=32'h00000000; BusB=32'h00000DEF;# (ClockDelay); // Should output 00000001
BusA=32'h00001234; BusB=32'h00000105;# (ClockDelay); // Should output 00000000
end
endmodule
Some advice, if you want synthesizable logic I recommend avoiding delays in your RTL. That code will simulate fine but if you compile it for an FPGA you might end up surprised by the way it behaves in actual hardware.
