4x4 keypad matriz
the only problem with the code is the problem with the keyboard rebounds and do not know how to fix it if someone could help me with the code would greatly appreciate it since I am on a project and I could not move through this jam that I have
my code:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
entity teclado is
port(
clock,rst : in std_logic;
col_line : in std_logic_vector(3 downto 0);
fila_line : out std_logic_vector(3 downto 0);
display : out std_logic_vector(6 downto 0)
end teclado;
architecture archi_teclado of teclado is
signal temp : std_logic_vector(29 downto 0);
CONSTANT max: INTEGER := 50000000;
signal clkout: std_logic;
--CONSTANT med: INTEGER := max/2;
CONSTANT half: INTEGER := max/50000;
SIGNAL count: INTEGER RANGE 0 TO half;
signal temp1: INTEGER RANGE 0 TO 16;
begin
PROCESS
BEGIN
WAIT UNTIL clock'EVENT and clock= '1';
IF (count < max) THEN
count <= count + 1;
ELSE
count <= 0;
END IF;
IF (count < half)THEN
clkout <= '0';
ELSE
clkout <= '1';
END IF;
END PROCESS;
key_driver: process(clkout,rst,temp,temp1)
begin
if(rst='0') then
temp1<=16;
elsif (clkout'event and clkout='1') then
temp <= temp + 1;
-- retraso:=retraso+1;
case temp(10 downto 8) is
when "000" =>
fila_line <= "0111"; --1 fila
when "001" =>
if col_line = "0111" then
-- display <= "0110000"; -- 3
temp1<=13;
elsif col_line = "1011" then
-- display <= "0100100"; -- 2
temp1<=15;
elsif col_line = "1101" then
-- display <= "1111001"; -- 1
temp1<=0;
elsif col_line = "1110" then
-- display <= "1000000"; -- 0
temp1<=14;
end if;
when "010" =>
fila_line <= "1011"; -- 2 fila
when "011" =>
-- if (delay='1') THEN
-- display <= "0011001"; -- 4
temp1<=7;
-- display <= "0010010"; -- 5
temp1<=8;
-- display <= "0000010"; -- 6
temp1<=9;
elsif col_line = "0111" then
-- display <= "1111000"; -- 7
temp1<=12;
end if;
-- end if;
when "100" =>
fila_line <= "1101"; -- 3 fila
when "101" =>
-- display <= "0000000"; -- 8
temp1<=4;
-- display <= "0010000"; -- 9
temp1<=5;
-- display <= "0001000"; -- a
temp1<=6;
-- display <= "0000011"; -- b
temp1<=11;
end if;
-- end if;
when "110" =>
fila_line <= "1110"; --4 fila
when "111" =>
-- display <= "1000110"; -- C
temp1<=1;
-- display <= "0100001"; -- d
temp1<=2;
-- display <= "0000110"; -- e
temp1<=3;
-- display <= "0001110"; -- f
temp1<=10;
end if;
--end if;
when others => null;
end case;
END IF;
CASE temp1 IS
when 0 => display <="1000000";
when 1 => display <="1111001";
when 2 => display <="0100100";
when 3 => display <="0110000";
when 4 => display <="0011001";
when 5 => display <="0010010";
when 6 => display <="0000010";
when 7 => display <="1111000";
when 8 => display <="0000000";
when 9 => display <="0010000";
when 10 => display <="0001000";
when 11 => display <="0000011";
when 12 => display <="1000110";
when 13 => display <="0100001";
when 14 => display <="0000110";
when 15 => display <="0001110";
when 16 => display <="ZZZZZZZ";
end case;
end process key_driver;
end archi_teclado;
Did you simulated this?
From a rapid glimpse to your code I got two major flaws:
- You defined count with a range 0 to half, but then you increment it up to max which is far beyond the specified range.
- If indeed your problem is with keyboard rebound you must sample the input signal at a slower rate: for example, assert clkout not when count<value but during a single cycle (i.e. IF (count = 0)THEN clkout <= '0'; ELSE clkout <= '1'; )
yes this proved physically and with a membrane keyboard
and if cris 72 the range of the account is reduced to the middle of the clock and change it and I narrowed it down to 5ms as the data sheet the keyboard has a debounce a 5ms approximate only thing that was changed CONSTANT hise half: INTEGER: = max/10000, this amount to an approximation of 5ms :)
