- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi all~~
When I use component editor to create a pwm,I add a HDL file .But,there are 6 errors and 1warning. I am a novice.And how can I do to deal with the problem. thanks~~ Info: Info: Info: ******************************************************************* Info: Info: Info: Running Quartus II Generate HDL Interface Info: Info: Info: Version 10.1 Build 153 11/29/2010 SJ Full Version Info: Info: Info: Copyright (C) 1991-2010 Altera Corporation. All rights reserved. Info: Info: Info: Your use of Altera Corporation's design tools, logic functions Info: Info: Info: and other software and tools, and its AMPP partner logic Info: Info: Info: functions, and any output files from any of the foregoing Info: Info: Info: (including device programming or simulation files), and any Info: Info: Info: associated documentation or information are expressly subject Info: Info: Info: to the terms and conditions of the Altera Program License Info: Info: Info: Subscription Agreement, Altera MegaCore Function License Info: Info: Info: Agreement, or other applicable license agreement, including, Info: Info: Info: without limitation, that your use is for the sole purpose of Info: Info: Info: programming logic devices manufactured by Altera and sold by Info: Info: Info: Altera or its authorized distributors. Please refer to the Info: Info: Info: applicable agreement for further details. Info: Info: Info: Processing started: Wed Apr 20 19:47:59 2011 Info: Info: Info: Command: quartus_map not_a_project --generate_hdl_interface=D:/sopc/pwm_source/pwm_hw/pwm_avalon_interface.v --source=D:/sopc/pwm_source/pwm_hw/pwm_avalon_interface.v --set=HDL_INTERFACE_OUTPUT_PATH=C:/DOCUME~1/S&H/LOCALS~1/Temp/alt5084_3622397843037451780.dir/0032_sopcqmap/ Error: Error: Error: The project or revision name contains one or more of the following illegal characters and cannot be opened: ^&?*|;' Warning: Warning: Error: Quartus II Generate HDL Interface was unsuccessful. 1 error, 0 warnings Error: Error: Error: Peak virtual memory: 172 megabytes Error: Error: Error: Processing ended: Wed Apr 20 19:47:59 2011 Error: Error: Error: Elapsed time: 00:00:00 Error: Error: Error: Total CPU time (on all processors): 00:00:00 Error: Error: No modules found when analyzing D:/sopc/pwm_source/pwm_hw/pwm_avalon_interface.v.コピーされたリンク
0 返答(返信)
