17241 Discussions
A sorter design issue
I want to design a sorter, which is used to allocate the new coming data to its proper loacation after comparing with all data inside the sorter. My algorithm is as below(pls check attachment:dengchang.jpg):
1. Compare the new data with all data inside the sorter (implemenmted with registers, just like data buffers).
2. Place the new data to proper position after comparing.
3. Shift all data behind the new data positon one step, and there is one data shifted out of the sorter.
There is negative setup slack issue after compilation. Each path between the new data and every regitser of the sorter has this timing issue. As the attached file:timing issue.jpg.
Unroll the Data Path. That's the interesting part. Your constraint looks correct, there's minimal clock skew, just too much logic or route on the data path.
Hi Rysc:
Yes, there is a too long "if elsif". So the tool sythnsesize it to many mux. The "if elsif"'s lenth is desided by the sorter's depth. However, i must need the sorter's depth not short than 30.
--- Quote Start ---
Hi Rysc:
--- Quote End ---
process(clkin,reset) begin if reset='0' then sorter_empty <= '1';dum_push <= '0';dum_cnt <= (others => '0'); reg1_sort <= (others => '0');reg2_sort <= (others => '0');reg3_sort <= (others => '0');reg4_sort <= (others => '0'); reg5_sort <= (others => '0');reg6_sort <= (others => '0');reg7_sort <= (others => '0');reg8_sort <= (others => '0');reg9_sort <= (others => '0'); reg10_sort <= (others => '0');reg11_sort <= (others => '0');reg12_sort <= (others => '0');reg13_sort <= (others => '0');reg14_sort <= (others => '0'); reg15_sort <= (others => '0');reg16_sort <= (others => '0');reg17_sort <= (others => '0');reg18_sort <= (others => '0');reg19_sort <= (others => '0'); reg20_sort <= (others => '0');reg21_sort <= (others => '0');reg22_sort <= (others => '0');reg23_sort <= (others => '0');reg24_sort <= (others => '0'); reg25_sort <= (others => '0');reg26_sort <= (others => '0');reg27_sort <= (others => '0');reg28_sort <= (others => '0');reg29_sort <= (others => '0'); reg30_sort <= (others => '0');reg31_sort <= (others => '0');reg32_sort <= (others => '0');reg33_sort <= (others => '0'); elsif clkin'event and clkin='1' then if d_valid='1' then dum_cnt <= (others => '0'); if sorter_empty='1' then reg1_sort <= reg0_sort; sorter_empty <= '0'; else--sorter_empty=0 if reg0_sort(46 downto 0)<reg32_sort(46 downto 0) then reg33_sort <= reg0_sort; elsif reg0_sort(46 downto 0)<reg31_sort(46 downto 0) then reg32_sort <= reg0_sort;reg33_sort <= reg32_sort; elsif reg0_sort(46 downto 0)<reg30_sort(46 downto 0) then reg31_sort <= reg0_sort;reg32_sort <= reg31_sort;reg33_sort <= reg32_sort; elsif reg0_sort(46 downto 0)<reg29_sort(46 downto 0) then reg30_sort <= reg0_sort; reg31_sort <= reg30_sort;reg32_sort <= reg31_sort;reg33_sort <= reg32_sort; elsif reg0_sort(46 downto 0)<reg28_sort(46 downto 0) then reg29_sort <= reg0_sort;reg30_sort <= reg29_sort; reg31_sort <= reg30_sort;reg32_sort <= reg31_sort;reg33_sort <= reg32_sort; elsif reg0_sort(46 downto 0)<reg27_sort(46 downto 0) then reg28_sort <= reg0_sort;reg29_sort <= reg28_sort;reg30_sort <= reg29_sort; reg31_sort <= reg30_sort;reg32_sort <= reg31_sort;reg33_sort <= reg32_sort; elsif reg0_sort(46 downto 0)<reg26_sort(46 downto 0) then reg27_sort <= reg0_sort;reg28_sort <= reg27_sort;reg29_sort <= reg28_sort; reg30_sort <= reg29_sort;reg31_sort <= reg30_sort;reg32_sort <= reg31_sort;reg33_sort <= reg32_sort; elsif reg0_sort(46 downto 0)<reg25_sort(46 downto 0) then .........
The problem is that you try to accomplish all the algorithm in one clock cycle. If you know that you won't have a valid data on each clock cycle, you can try and divide your code in two or more blocks and only execute one of the blocks on each clock cycle.
If you can have new data on each cycle, then you will need to use pipelining and will need a major rewrite of the code. A way to do this would be to "propagate" an incoming data through your registers, pushing it one level on each clock cycle until it reaches the correct place, and then propagate the existing data, pushing the values one level down on each clock cycle. I'm not sure what I'm laying is very clear. If you don't see what I mean, tell me and I'll do a schematic of what I'm thinking.
