17255 Discussions
ALTERA_FP_FUNCTIONS reusability
MrZaiko
I'm working on Quartus v18.1. First, I'm sorry if this question is basic but I'm new and I cannot find any information on the web.
In my project, I use floating point components of Quartus such as altfp_add_sub and altfp_mult. They are very useful because with just the component declaration and instantiation, I can use them "out of the box". The files I'm writing need to directly work when put in another quartus project without particular settings.
Problem, when I was using altfp_mult, I had the problem described in this post : https://community.intel.com/t5/FPGA-Intellectual-Property/ALTFP-MULT-issues/m-p/121775#M9766%3Fwapkw=altfp_mult%20error
Following the advice, I'm using the ALTERA_FP_FUNCTIONS. But, is there a way to make it works the same way as altfp_add_sub without having to regenerate a component (using the ip catalog...) with the name used in the files for each new projects ?
Again I'm sorry if the question is basic but I'm quite lost,
Thank you in advance!
SyafieqS
Hi Sami,
Kindly check your email
SyafieqS
Hi Sami,
Any update?
