Hi everyone,
I am new to the Altera world and I am using the altera aoc compiler for implementing my OpenCL application on an Altera FPGA. I have a kernel code, written in OpenCL that calls some functions. I tested the code on a GPU and on my CPU and everything works great, the problem is that whenever I try to compile the kernel code with aoc, the tool crashes giving me this call:
aocl-clang: CGCall.cpp:1492: void checkArgMatches(llvm::Value*, unsigned int&, llvm::FunctionType*): Assertion `Elt->getType() == FTy->getParamType(ArgNo)' failed.
0 libLLVM-3.0.so 0x00007fe47dd913af
1 libLLVM-3.0.so 0x00007fe47dd93322
2 libpthread.so.0 0x00007fe47cd5c3e0
3 libc.so.6 0x00007fe47bd6f428 gsignal + 56
4 libc.so.6 0x00007fe47bd7102a abort + 362
5 libc.so.6 0x00007fe47bd67bd7
6 libc.so.6 0x00007fe47bd67c82
7 aocl-clang 0x0000000000775768 clang::CodeGen::CodeGenFunction::EmitCall(clang::CodeGen::CGFunctionInfo const&, llvm::Value*, clang::CodeGen::ReturnValueSlot, clang::CodeGen::CallArgList const&, clang::Decl const*, llvm::Instruction**) + 2712
8 aocl-clang 0x00000000007b8933 clang::CodeGen::CodeGenFunction::EmitCall(clang::QualType, llvm::Value*, clang::CodeGen::ReturnValueSlot, clang::ConstExprIterator, clang::ConstExprIterator, clang::Decl const*) + 883
9 aocl-clang 0x00000000007c3452 clang::CodeGen::CodeGenFunction::EmitCallExpr(clang::CallExpr const*, clang::CodeGen::ReturnValueSlot) + 530
10 aocl-clang 0x00000000007e4466
11 aocl-clang 0x00000000007ec6ce
12 aocl-clang 0x00000000007ed260 clang::CodeGen::CodeGenFunction::EmitScalarExpr(clang::Expr const*, bool) + 96
13 aocl-clang 0x00000000007a2507 clang::CodeGen::CodeGenFunction::EmitScalarInit(clang::Expr const*, clang::ValueDecl const*, clang::CodeGen::LValue, bool) + 807
14 aocl-clang 0x00000000007a2b8b clang::CodeGen::CodeGenFunction::EmitExprAsInit(clang::Expr const*, clang::ValueDecl const*, clang::CodeGen::LValue, bool) + 587
15 aocl-clang 0x00000000007a3e41 clang::CodeGen::CodeGenFunction::EmitAutoVarInit(clang::CodeGen::CodeGenFunction::AutoVarEmission const&) + 1937
16 aocl-clang 0x00000000007a5833 clang::CodeGen::CodeGenFunction::EmitAutoVarDecl(clang::VarDecl const&) + 83
17 aocl-clang 0x000000000084815f clang::CodeGen::CodeGenFunction::EmitDeclStmt(clang::DeclStmt const&) + 127
18 aocl-clang 0x00000000008529a5 clang::CodeGen::CodeGenFunction::EmitSimpleStmt(clang::Stmt const*) + 101
19 aocl-clang 0x000000000084eb77 clang::CodeGen::CodeGenFunction::EmitStmt(clang::Stmt const*) + 39
20 aocl-clang 0x0000000000852790 clang::CodeGen::CodeGenFunction::EmitCompoundStmt(clang::CompoundStmt const&, bool, clang::CodeGen::AggValueSlot) + 272
21 aocl-clang 0x0000000000852a4f clang::CodeGen::CodeGenFunction::EmitSimpleStmt(clang::Stmt const*) + 271
22 aocl-clang 0x000000000084eb77 clang::CodeGen::CodeGenFunction::EmitStmt(clang::Stmt const*) + 39
23 aocl-clang 0x0000000000851ee6 clang::CodeGen::CodeGenFunction::EmitForStmt(clang::ForStmt const&) + 1414
24 aocl-clang 0x0000000000852790 clang::CodeGen::CodeGenFunction::EmitCompoundStmt(clang::CompoundStmt const&, bool, clang::CodeGen::AggValueSlot) + 272
25 aocl-clang 0x0000000000852a4f clang::CodeGen::CodeGenFunction::EmitSimpleStmt(clang::Stmt const*) + 271
26 aocl-clang 0x000000000084eb77 clang::CodeGen::CodeGenFunction::EmitStmt(clang::Stmt const*) + 39
27 aocl-clang 0x0000000000851ee6 clang::CodeGen::CodeGenFunction::EmitForStmt(clang::ForStmt const&) + 1414
28 aocl-clang 0x0000000000852790 clang::CodeGen::CodeGenFunction::EmitCompoundStmt(clang::CompoundStmt const&, bool, clang::CodeGen::AggValueSlot) + 272
29 aocl-clang 0x0000000000852a4f clang::CodeGen::CodeGenFunction::EmitSimpleStmt(clang::Stmt const*) + 271
30 aocl-clang 0x000000000084eb77 clang::CodeGen::CodeGenFunction::EmitStmt(clang::Stmt const*) + 39
31 aocl-clang 0x0000000000861cdb clang::CodeGen::CodeGenFunction::GenerateCode(clang::GlobalDecl, llvm::Function*, clang::CodeGen::CGFunctionInfo const&) + 715
32 aocl-clang 0x0000000000743f94 clang::CodeGen::CodeGenModule::EmitGlobalFunctionDefinition(clang::GlobalDecl) + 660
33 aocl-clang 0x000000000074528e clang::CodeGen::CodeGenModule::EmitGlobalDefinition(clang::GlobalDecl) + 190
34 aocl-clang 0x000000000074589d clang::CodeGen::CodeGenModule::EmitGlobal(clang::GlobalDecl) + 1229
35 aocl-clang 0x0000000000745cc1 clang::CodeGen::CodeGenModule::EmitTopLevelDecl(clang::Decl*) + 449
36 aocl-clang 0x000000000071ba64
37 aocl-clang 0x000000000071b401 clang::BackendConsumer::HandleTopLevelDecl(clang::DeclGroupRef) + 161
38 aocl-clang 0x0000000000881de4 clang::ParseAST(clang::Sema&, bool) + 308
39 aocl-clang 0x000000000071a7c4 clang::CodeGenAction::ExecuteAction() + 68
40 aocl-clang 0x00000000005ab835 clang::CompilerInstance::ExecuteAction(clang::FrontendAction&) + 373
41 aocl-clang 0x0000000000592779 clang::ExecuteCompilerInvocation(clang::CompilerInstance*) + 1401
42 aocl-clang 0x0000000000588a9a cc1_main(char const**, char const**, char const*, void*) + 618
43 aocl-clang 0x00000000005914f7 main + 7015
44 libc.so.6 0x00007fe47bd5a830 __libc_start_main + 240
45 aocl-clang 0x0000000000587039
Does anyone know why all this is happening? Thanks for your help
can you post your .cl?
can't post the original version but it is something like this
void function1( my_type * arg_1, my_type_2 *arg_2){
//normale opencl c code
__kernel kernel_1(__global my_type * arg_1, __global my_type_2 * arg_2, __global my_type * out)
//doing some stuff that works correctly
function1(arg_1, arg_2);
where my_type are structs. I tested the code and I found out the problem to be the function call. I do not understand why, just having a function call cause aoc to crash. I tried commenting out everything that was inside the function and still the tool was crashing... Any clue?
Topic Options
