17249 Discussions
AOC crashes when using kernel with function calls
Hi everyone,
I am new to the Altera world and I am using the altera aoc compiler for implementing my OpenCL application on an Altera FPGA.
I have a kernel code, written in OpenCL that calls some functions. I tested the code on a GPU and on my CPU and everything works great, the problem is that whenever I try to compile the kernel code with aoc, the tool crashes giving me this call:
aocl-clang: CGCall.cpp:1492: void checkArgMatches(llvm::Value*, unsigned int&, llvm::FunctionType*): Assertion `Elt->getType() == FTy->getParamType(ArgNo)' failed. 0 libLLVM-3.0.so 0x00007fe47dd913af 1 libLLVM-3.0.so 0x00007fe47dd93322 2 libpthread.so.0 0x00007fe47cd5c3e0 3 libc.so.6 0x00007fe47bd6f428 gsignal + 56 4 libc.so.6 0x00007fe47bd7102a abort + 362 5 libc.so.6 0x00007fe47bd67bd7 6 libc.so.6 0x00007fe47bd67c82 7 aocl-clang 0x0000000000775768 clang::CodeGen::CodeGenFunction::EmitCall(clang::CodeGen::CGFunctionInfo const&, llvm::Value*, clang::CodeGen::ReturnValueSlot, clang::CodeGen::CallArgList const&, clang::Decl const*, llvm::Instruction**) + 2712 8 aocl-clang 0x00000000007b8933 clang::CodeGen::CodeGenFunction::EmitCall(clang::QualType, llvm::Value*, clang::CodeGen::ReturnValueSlot, clang::ConstExprIterator, clang::ConstExprIterator, clang::Decl const*) + 883 9 aocl-clang 0x00000000007c3452 clang::CodeGen::CodeGenFunction::EmitCallExpr(clang::CallExpr const*, clang::CodeGen::ReturnValueSlot) + 530 10 aocl-clang 0x00000000007e4466 11 aocl-clang 0x00000000007ec6ce 12 aocl-clang 0x00000000007ed260 clang::CodeGen::CodeGenFunction::EmitScalarExpr(clang::Expr const*, bool) + 96 13 aocl-clang 0x00000000007a2507 clang::CodeGen::CodeGenFunction::EmitScalarInit(clang::Expr const*, clang::ValueDecl const*, clang::CodeGen::LValue, bool) + 807 14 aocl-clang 0x00000000007a2b8b clang::CodeGen::CodeGenFunction::EmitExprAsInit(clang::Expr const*, clang::ValueDecl const*, clang::CodeGen::LValue, bool) + 587 15 aocl-clang 0x00000000007a3e41 clang::CodeGen::CodeGenFunction::EmitAutoVarInit(clang::CodeGen::CodeGenFunction::AutoVarEmission const&) + 1937 16 aocl-clang 0x00000000007a5833 clang::CodeGen::CodeGenFunction::EmitAutoVarDecl(clang::VarDecl const&) + 83 17 aocl-clang 0x000000000084815f clang::CodeGen::CodeGenFunction::EmitDeclStmt(clang::DeclStmt const&) + 127 18 aocl-clang 0x00000000008529a5 clang::CodeGen::CodeGenFunction::EmitSimpleStmt(clang::Stmt const*) + 101 19 aocl-clang 0x000000000084eb77 clang::CodeGen::CodeGenFunction::EmitStmt(clang::Stmt const*) + 39 20 aocl-clang 0x0000000000852790 clang::CodeGen::CodeGenFunction::EmitCompoundStmt(clang::CompoundStmt const&, bool, clang::CodeGen::AggValueSlot) + 272 21 aocl-clang 0x0000000000852a4f clang::CodeGen::CodeGenFunction::EmitSimpleStmt(clang::Stmt const*) + 271 22 aocl-clang 0x000000000084eb77 clang::CodeGen::CodeGenFunction::EmitStmt(clang::Stmt const*) + 39 23 aocl-clang 0x0000000000851ee6 clang::CodeGen::CodeGenFunction::EmitForStmt(clang::ForStmt const&) + 1414 24 aocl-clang 0x0000000000852790 clang::CodeGen::CodeGenFunction::EmitCompoundStmt(clang::CompoundStmt const&, bool, clang::CodeGen::AggValueSlot) + 272 25 aocl-clang 0x0000000000852a4f clang::CodeGen::CodeGenFunction::EmitSimpleStmt(clang::Stmt const*) + 271 26 aocl-clang 0x000000000084eb77 clang::CodeGen::CodeGenFunction::EmitStmt(clang::Stmt const*) + 39 27 aocl-clang 0x0000000000851ee6 clang::CodeGen::CodeGenFunction::EmitForStmt(clang::ForStmt const&) + 1414 28 aocl-clang 0x0000000000852790 clang::CodeGen::CodeGenFunction::EmitCompoundStmt(clang::CompoundStmt const&, bool, clang::CodeGen::AggValueSlot) + 272 29 aocl-clang 0x0000000000852a4f clang::CodeGen::CodeGenFunction::EmitSimpleStmt(clang::Stmt const*) + 271 30 aocl-clang 0x000000000084eb77 clang::CodeGen::CodeGenFunction::EmitStmt(clang::Stmt const*) + 39 31 aocl-clang 0x0000000000861cdb clang::CodeGen::CodeGenFunction::GenerateCode(clang::GlobalDecl, llvm::Function*, clang::CodeGen::CGFunctionInfo const&) + 715 32 aocl-clang 0x0000000000743f94 clang::CodeGen::CodeGenModule::EmitGlobalFunctionDefinition(clang::GlobalDecl) + 660 33 aocl-clang 0x000000000074528e clang::CodeGen::CodeGenModule::EmitGlobalDefinition(clang::GlobalDecl) + 190 34 aocl-clang 0x000000000074589d clang::CodeGen::CodeGenModule::EmitGlobal(clang::GlobalDecl) + 1229 35 aocl-clang 0x0000000000745cc1 clang::CodeGen::CodeGenModule::EmitTopLevelDecl(clang::Decl*) + 449 36 aocl-clang 0x000000000071ba64 37 aocl-clang 0x000000000071b401 clang::BackendConsumer::HandleTopLevelDecl(clang::DeclGroupRef) + 161 38 aocl-clang 0x0000000000881de4 clang::ParseAST(clang::Sema&, bool) + 308 39 aocl-clang 0x000000000071a7c4 clang::CodeGenAction::ExecuteAction() + 68 40 aocl-clang 0x00000000005ab835 clang::CompilerInstance::ExecuteAction(clang::FrontendAction&) + 373 41 aocl-clang 0x0000000000592779 clang::ExecuteCompilerInvocation(clang::CompilerInstance*) + 1401 42 aocl-clang 0x0000000000588a9a cc1_main(char const**, char const**, char const*, void*) + 618 43 aocl-clang 0x00000000005914f7 main + 7015 44 libc.so.6 0x00007fe47bd5a830 __libc_start_main + 240 45 aocl-clang 0x0000000000587039
Does anyone know why all this is happening?
Thanks for your help
can you post your .cl?
can't post the original version but it is something like this
void function1( my_type * arg_1, my_type_2 *arg_2){ //normale opencl c code } __kernel kernel_1(__global my_type * arg_1, __global my_type_2 * arg_2, __global my_type * out) { //doing some stuff that works correctly function1(arg_1, arg_2); //doing some stuff that works correctly }
where my_type are structs.
I tested the code and I found out the problem to be the function call. I do not understand why, just having a function call cause aoc to crash.
I tried commenting out everything that was inside the function and still the tool was crashing...
Any clue?
