AXI 4 to AXI 4 lite
Jewel
Is there any bridge in platform designer which converts AXI 4 transactions  to AXI 4 lite transactions or is there any other way to do that ?
sstrell
Just connect the interfaces together.  The interconnect should get built automatically to handle it.
Jewel
Hi ,
Thank you for your response , actually the situation is i have to export a axi4 interface which is in qsys top and get connect it with a axi4 lite  interface which is outside  qsys top . I know that in platform designer this interconnect is internally taken care but what i should do in the above situation.
ShengN_Intel
you can make connections without the use of explicitly-instantiated bridges; the interconnect provides all necessary bridging logic.
Sheng
Jewel
Hi Sheng ,
ShengN_Intel
Easier way is to include axi4 lite interface into the platform designer system qsys top as new component (component editor) link https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/specify-ip-component-type-information.html or as a subsystem link https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/adding-a-subsystem-to-a-system.html
Sheng
Jewel
Thank you , i will look into this and let you know.
ShengN_Intel
Sure. Let me know if you have any further update or concern.
Sheng
