17249 ディスカッション
Arria V clock no output dependent(15610)
EBoln
新規コントリビューター I
1,267件の閲覧回数
HI!
i am using arria v for a new project but ran into the following behavior:
- when I only use logic, the clock pin is synthesized successfully
- when I add video ip core to the project, then all the logic connected to this clock pin is not synthesized
Why? Project in attachments(i'm use Q18.1.1)
thank
P.S. on RTL viewer all is OK, but post-mapping clock network is absent
0 件の賞賛
1 解決策
EBoln
新規コントリビューター I
1,224件の閲覧回数
Found a bug in my custom qsys module, the reset was confused
元の投稿で解決策を見る
3 返答(返信)
JonWay_C_Intel
従業員
1,240件の閲覧回数
Hi EBoln,
There is no attachment. If your project is huge, could you send us a simplified design that shows the problem. Thanks.
EBoln
新規コントリビューター I
1,225件の閲覧回数
JonWay_C_Intel
従業員
1,218件の閲覧回数
Thanks @EBoln  for sharing the root cause of the problem.
返信
