17244 Discussions
Arria V clock no output dependent(15610)
EBoln
HI!
i am using arria v for a new project but ran into the following behavior:
- when I only use logic, the clock pin is synthesized successfully
- when I add video ip core to the project, then all the logic connected to this clock pin is not synthesized
Why? Project in attachments(i'm use Q18.1.1)
thank
P.S. on RTL viewer all is OK, but post-mapping clock network is absent
EBoln
Found a bug in my custom qsys module, the reset was confused
JonWay_C_Intel
Hi EBoln,
There is no attachment. If your project is huge, could you send us a simplified design that shows the problem. Thanks.
EBoln
JonWay_C_Intel
Thanks @EBoln  for sharing the root cause of the problem.
