17267 Discussions
Big Problems with bidir Pin :-)
I have a problem with the bidir pins in Quartus II.
I made a simple project to demonstrate this.
http://rapidshare.com/files/32982986/iobuff_test.zip.html (http://rapidshare.com/files/32982986/iobuff_test.zip.html
If oe=1, the value on "in" (which is alleways '1') should be going to "io".
In the simulation you see, that the simulator generates a new variable called "io~result". This variable has the right value, which the bidirectinal pin also should have.
But the bidir pin "io" allways stay "undefined". Why???
I searched for other examples with this pin but I can't find them.
Is there no way to work with I/Os?
It would be gratefull if someone has s solution, or better an example to handle bidirectinal pins.
Chrisitan
When QII simulator simulates the bidirectional pin (e.g. your bidirectional pin name is bidir_io), it will automatically create the bidir_io~result. bidir_io represents the input channel of the bidirectional pin and bidir_io~result represents the output channel of the bidirectional pin.
Therefore your bidir_io~result displays the correct output when OE=1. As for why bidir_io is X is because you do not set any input vector to it. In short, the QII simulator breaks the bidirectional pin to input (e.g bidir_io) and output (e.g. bidir_io~result) in the simulation waveform.
Hope it helps.
thank you for your reply.
It's a good explanation for the added variable.
So, I made a new vwf-file to test this, besides I erased the clock, because I don't net it.
The new project: http://rapidshare.com/files/33104146/iobuff_test.zip.html (http://rapidshare.com/files/33104146/iobuff_test.zip.html
The VHDL Code works this way, that if oe='0' the value I set to "io" is shown on the output.
But then I want the value on input to be shown on io~result. I set oe='1' and the value on "io" to "DC" (Don't Care).
On the simulation you see, that the value an io~result (which should be the same linke "in") is unknown.
I have no idea why this value is unknown. It should work like described in the VHDL Code.
It makes no sense to give "io" another value for the time oe='1' because this value will be the same like on io~result.
Christian
