17249 Discussões
Blacl Box synthesis attribute
Colaborador honorário II
1.639 Visualizações
Im trying to tell the Quartus 2 synthesiser that my component is a black box so it doesnt complain that it cant find the entity declaration. Ive tried all of the following in the VHDL top level:
attribute syn_black_box, black_box, noopt : boolean ;
attribute (whatever) of my_comp : component is true;
None of them seem to work and when I go through analysis and elaboration is complains it cant find the entity for "my_comp". what is the correct attribute to use?
3 Respostas
720 Visualizações
How do you physically want it to place-and-route a black-box? (I ask because until recently, you really couldn't do a black-box)
I create the normal entity and then do:
architecture bb of entityname is
begin
end bb;
So there's nothing in it. I then run analysis and elaboration to get the hierarchy, right-click on this hierarchy in the hierarchy browser and create a partition. Then I open Assignments -> Design Partitions Window and set that partition to Empty.
720 Visualizações
I dont want to P&R it, I just want to synthesise with a black box in place.
This isnt the entire TL as a black box - a component called at the top level I want to be a black box (so other stuff is synthesized, this component isnt, for now).
720 Visualizações
That flow works for synthesis and P&R. I don't know what happens if you don't add the empty partition assignment, i.e. if it keeps all the port connections or rips out everything since they don't drive anything. It might keep them, but not sure. If you have the web edition, I don't think you have incremental compilation/partition access, but if you do it's real easy to add that in.
Responder
