17268 Discussions
Building hello_world issue with embedded_command_shell
Hi, I have tried building hello_world host as well as other examples from de10_nano BSP. However, none of them were built successfully.
They all met the same question:
$ make
arm-linux-gnueabihf-g++: 閿欒锛?libpath:E:/intelFPGA/17.1/hld/host/windows64/l
ib锛欼nvalid argument
arm-linux-gnueabihf-g++: 閿欒锛歄penCL.lib锛歂o such file or directory
make: *** [bin/hello_world] Error 1
Please help me get rid of the issue above. Thanks a lot!
There is another problem :
g++ ./host/main.o ../common/ocl_util.o ../common/timer.o -o run /libpath:E:/in
telFPGA/17.1/hld/host/windows64/lib OpenCL.lib -lacl_emulator_kernel_rt
g++: error:/libpath:E:/intelFPGA/17.1/hld/host/windows64/lib:No such file or di
rectory
g++: error:OpenCL.lib:No such file or directory
make: *** [run] Error 1
How can I solve that? Please help me. Thanks a lot!
Your environment does not seem to be set correctly. Follow Terasic's guides to set up your environment.
--- Quote Start ---
--- Quote End ---
Thanks for your answer. The environment I followed is the document named DE10-Nano OpenCL User Manual.pdf which I downloaded from the official website. I have set the environment AOCL_BOARD_PACKAGE_ROOT, LM_LICENSE_FILE, INTELFPGAOCLSDKROOT. As well as the two directories have been added into the PATH.
I can compile all the kernels to generate aocx file but I have never get the host files compiled. Is there anything wrong? Looking forward to your reply.
You seem to have some Chinese characters in your path variables. It is likely that the compiler cannot parse such characters correctly. Apart from that, you seem to be using Cygwin on Windows. I am not sure if that is a supported method for compiling kernels against Intel FPGA SDK for OpenCL.
