17268 Discussions
Bus Error while booting FPGA Hardwaare
Shwetha_G_S
We use "10AS048E3F29I2SG" (Arria 10) device.
While booting the fpga hardware, in serial prints following bus error is coming
Fail: noc_idleack = 0x01110111 mask_noc = 0x00100111
Kernel image @ 0x008000 [ 0x000000 - 0x4fd948 ]
prg <page> <reg>
[ 108.745414] Unhandled fault: external abort on non-linefetch (0x818) at 0xb6c87240
[ 108.752962] pgd = ed9e8000
[ 108.755656] [b6c87240] *pgd=7fcd5831
Bus error
Plz analyze the issue.Whether this is hardware or software issue?
Kindly give a solution for this asap.
EBERLAZARE_I_Intel
How did you build your bootloader?
Also, could you share your full booting logs?
Which version of Uboot are you using?
Have you had successful logs in the past for this board?
Shwetha_G_S
We are using U-Boot 2014.10 version.
Full booting logs have been attached.
We had successful logs in the past for this same arria 10 device
EBERLAZARE_I_Intel
Do you have any update?
EBERLAZARE_I_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
