17259 Discussions
[COMPILE] Error: DSP Builder
Hi again!
I get an error when tying to compile with the flag -c:
aoc -v -c cluster_k.cl
then:
Internal Error: DSP Builder for Intel(R) FPGAs - Advanced Blockset Internal Restriction: 'm_startVec.size() > 0' in commonBackend::EnumerateLatencyConstraints::Private::beginSetIteration at p4/ip/aion/src/mip_common/latency_constraint_iterator.cpp:268.
the line that is causing this error is:
b2 = ceil(components * tolerance);
components is an integer that is incremented through a loop, tolerance is a constant double.
Whats the problem with the above line? (Also b2 is integer)
Thanks in advance
This looks like a bug in the compiler. Try the latest version of Quartus, v17.1. If you still got the same error, open a support ticket with Altera and report it.
--- Quote Start ---
--- Quote End ---
from the specification, they say that the return value and arguments must be of the same type..
https://www.khronos.org/registry/opencl/sdk/2.0/docs/man/xhtml/ceil.html
So i changed it and no problem. Thanks HRZ :cool:
Excuse me, could you tell me how to open a support ticket with Altera? I met a same question with you.
Thank you very much!
Excuse me, could you tell me how to open a support ticket with Altera? I met a same question whether Quartus 16.0 or 17.0 can solve the error.
--- Quote Start ---
--- Quote End ---
Go to altera.com, create an account, log in, and open a service request.
