17256 Discussions
Can Avalon-MM Slave BFM Intel FPGA IP be used to implement a memory block?
gyuunyuu
In a memory block, reading the same address, shall give the same data value. Can this be implemented using the Avalon-MM Slave BFM Intel FPGA IP for verification purpose?
gyuunyuu
The "Avalon Verification IP Suite: User Guide" mentions a memory_mode on page 47:
"Response Generator and Data Cache— In memory_mode the Slave BFM models a single port RAM. A write operation stores the data in an associative array and generates no response. A read operation fetches data from the array and drives it on the response side of the Avalon interface. This mode simplifies loopback testing. "
However, there is absolutely nothing with this name anywhere outside this document. I have done a search of the .sv file of the BFM. I have not found anything there. Is this some sort of mistake?
gyuunyuu
There is also this function called set_response_timeout which has been left inside the altera_avalon_mm_slave_bfm.sv but does absolutely nothing. Why is this so?
EricMunYew_C_Intel
The Avalon-MM Slave BFM is a bridge and cannot be used to implement memory block.
ThomasTessier
Did anyone write an example using the APIs to create the simple Memory Read and Memory Write Device using the avalon_mm_slave_bfm?  There is a lot of power in the API but I could see just doing basic command response and command processing to build such a function.  I would find it preferred over rolling my own and the avalon_mm_slave_bfm already has all the hooks and checks for proper operation on the Avalon Bus.
I think a lot of us could use an example like this?
TomT...
