17253 Discussions
Can I use SignalTap to probe LVDS transmitter output?
If I am using CII or SII, can I use SignalTap to debug a LVDS serializer output if the number of channels is 12 or 16?
I found this post on www.altera.com,
http://www.altera.com/support/kdb/solutions/rd07042005_25.html
How about for CII and SII devices? Is there bit width limitation?
Many Thanks!
The only LVDS limitation mentioned in the SignalTap chapter of the Quartus handbook:
--- Quote Start ---
Untappable Signals
Not all of the post-fitting signals in your design are available in the SignalTap II: post-fitting filter in the Node Finder dialog box. The following signal types cannot be tapped:
■ LVDS—You cannot tap the data output from a serializer/deserializer (SERDES) block.
--- Quote End ---
Thanks Brad!
It is really bad news for me though. :( Wonder if there are other ways to probe a serializer output other than using an oscilloscope...
try post-fit simulation and DSO
