17252 Discussions
Can't get Altera JTAG Server service running on Windows 7
Contributeur émérite II
8 934 Visites
I recently upgraded from Quartus 9.1 on Windows XP to Quartus 11.0 on Windows 7 64-bit. At one point my USB Blaster was working, but it stopped (it may have been after a Windows OS auto-update?).
The quartus programmer gives "Attempted to access JTAG server -- internal error code 82 occurred". I disabled my firewall, but the error persists.
When I look at the Services window, "Altera JTAG Server" is not present at all, so I could not start the service. I ran the sc (service control app) from an elevated command prompt (admin rights enabled) as follows:
sc create "Altera JTAG Server" binpath= C:\altera\11.0\quartus\bin\jtagserver.exe
This successfully created the service for me, but I still can't start it. I get Error 1053 - service did not respond to start in timely fashion. The service appears configured identically as my old machine except for the path to jtagserver.exe
After I removed virus scanning software and firewall protection, I re-installed Quartus II ver 11.0, but still have the same problem. The USB Blaster shows up as "Altera USB-Blaster" in the Device Manager, so I think it is set up right.
Any ideas?
0 Compliments
15 Réponses
5 273 Visites
I got it working by downgrading to version 10.1 sp1 and loading the same project. As soon as I tried to open the programmer, it immediately threw up a modal dialog box saying it could not start the jtag server service, with "Error opening SCM" as the reason.
The strange thing was, after I dismissed the dialog box, the USB blaster was finally listed as one of hardware devices I could select (before it was only "No Hardware"). I checked the windows services and sure enough, I cannot find any "Altera JTAG Server", but it didn't seem to care.
I went back to version 11.0 and it also works now. This was a painful experiment. I don't know if it is broadly applicable.
0 Compliments
5 273 Visites
I had the same problem after installing q11.0. I tried different things but there was no usb blaster available. After this i installed q10.1 without uninstalling q11.0 and now the usb blaster was selectable in both versions of quartus. Then i uninstalled q10.1 and then there was no blaster selectable again.
I solved the problem by installing the stand alone programmer (v11) after installing q11.0.
0 Compliments
5 273 Visites
It would appear they forgot to ship the 64bit programmer with q11.
0 Compliments
5 273 Visites
--- Quote Start ---
--- Quote End ---
I would appear they forgot to ship the entire 64-bit product with Q11 Web/Windows.
0 Compliments
5 273 Visites
I guess it is a "feature," the system requirements for Q11 Web only say 32bit. Hopefully it wasn't decided in the same meeting where they made parallel compiling a pro feature.
0 Compliments
5 273 Visites
ow loverly, just installed 11 version on PC and laptop and here also the USBblaster is not working.
i hope its just a bug, this is really annoying.
0 Compliments
5 273 Visites
Andre.krueger (above) has the correct answer.
You need the 64 bit jtagserver on a 64 bit kernel as the kernel 32/64 bit conversions sometimes have problems - the 32 bit jtagserver is unreliable on a 64 bit kernel.
Installing the 11.0 programmer install after the 11.0 web edition should get the correct files installed.
0 Compliments
5 273 Visites
installing the programmer software indeed fixed it :)
0 Compliments
5 273 Visites
Yup, had the same problem until I installed the stand-alone programmer 11.0. Here is the link to download it: https://www.altera.com/download/programming/quartus2/pq2-index.jsp
0 Compliments
5 273 Visites
Same for med, spent two days looking for a solution and finally found this thread. Worked after installing the 10.1 standalone programmer.
(I'm on win7 64 and it said that the jtag server couldn't start on a 64-bit system).
Altera, perhaps some testing would be in place before you release new stuff?
0 Compliments
5 273 Visites
Thank You very much. Thats it!
0 Compliments
5 273 Visites
thanks for the tips
0 Compliments
5 273 Visites
--- Quote Start ---
--- Quote End ---
thank you very much, it is working now, i tried many solutions but only this one is correct for me. Your link also was very helpful.
0 Compliments
5 273 Visites
Thank you vary much!! I gave my 5 hours to solve JTAG server error. When I'm using v11 everthing was fine. I install Quartus II v12 sp2 system crashed down. Cant't connet the wire becaouse of error 82...etc...
Thank you...
0 Compliments
5 273 Visites
Yes,
Installing Quartus programmer is the solution for resolving JTAG error.
Initially i had 12.0 version and no JTAG service was running.Installing programmer
installs local JTAG server and this solves all problems.. :)
0 Compliments
Répondre
