- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I recently upgraded from Quartus 9.1 on Windows XP to Quartus 11.0 on Windows 7 64-bit. At one point my USB Blaster was working, but it stopped (it may have been after a Windows OS auto-update?).
The quartus programmer gives "Attempted to access JTAG server -- internal error code 82 occurred". I disabled my firewall, but the error persists. When I look at the Services window, "Altera JTAG Server" is not present at all, so I could not start the service. I ran the sc (service control app) from an elevated command prompt (admin rights enabled) as follows: sc create "Altera JTAG Server" binpath= C:\altera\11.0\quartus\bin\jtagserver.exe This successfully created the service for me, but I still can't start it. I get Error 1053 - service did not respond to start in timely fashion. The service appears configured identically as my old machine except for the path to jtagserver.exe After I removed virus scanning software and firewall protection, I re-installed Quartus II ver 11.0, but still have the same problem. The USB Blaster shows up as "Altera USB-Blaster" in the Device Manager, so I think it is set up right. Any ideas?Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I got it working by downgrading to version 10.1 sp1 and loading the same project. As soon as I tried to open the programmer, it immediately threw up a modal dialog box saying it could not start the jtag server service, with "Error opening SCM" as the reason.
The strange thing was, after I dismissed the dialog box, the USB blaster was finally listed as one of hardware devices I could select (before it was only "No Hardware"). I checked the windows services and sure enough, I cannot find any "Altera JTAG Server", but it didn't seem to care. I went back to version 11.0 and it also works now. This was a painful experiment. I don't know if it is broadly applicable.- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I had the same problem after installing q11.0. I tried different things but there was no usb blaster available. After this i installed q10.1 without uninstalling q11.0 and now the usb blaster was selectable in both versions of quartus. Then i uninstalled q10.1 and then there was no blaster selectable again.
I solved the problem by installing the stand alone programmer (v11) after installing q11.0.- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
It would appear they forgot to ship the 64bit programmer with q11.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
--- Quote Start --- It would appear they forgot to ship the 64bit programmer with q11. --- Quote End --- I would appear they forgot to ship the entire 64-bit product with Q11 Web/Windows.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I guess it is a "feature," the system requirements for Q11 Web only say 32bit. Hopefully it wasn't decided in the same meeting where they made parallel compiling a pro feature.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
ow loverly, just installed 11 version on PC and laptop and here also the USBblaster is not working.
i hope its just a bug, this is really annoying.- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Andre.krueger (above) has the correct answer.
You need the 64 bit jtagserver on a 64 bit kernel as the kernel 32/64 bit conversions sometimes have problems - the 32 bit jtagserver is unreliable on a 64 bit kernel. Installing the 11.0 programmer install after the 11.0 web edition should get the correct files installed.- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
installing the programmer software indeed fixed it :)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Yup, had the same problem until I installed the stand-alone programmer 11.0. Here is the link to download it: https://www.altera.com/download/programming/quartus2/pq2-index.jsp
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Same for med, spent two days looking for a solution and finally found this thread. Worked after installing the 10.1 standalone programmer.
(I'm on win7 64 and it said that the jtag server couldn't start on a 64-bit system). Altera, perhaps some testing would be in place before you release new stuff?- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thank You very much. Thats it!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
thanks for the tips
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
--- Quote Start --- Yup, had the same problem until I installed the stand-alone programmer 11.0. Here is the link to download it: --- Quote End --- thank you very much, it is working now, i tried many solutions but only this one is correct for me. Your link also was very helpful.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thank you vary much!! I gave my 5 hours to solve JTAG server error. When I'm using v11 everthing was fine. I install Quartus II v12 sp2 system crashed down. Cant't connet the wire becaouse of error 82...etc...
Thank you...- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Yes,
Installing Quartus programmer is the solution for resolving JTAG error. Initially i had 12.0 version and no JTAG service was running.Installing programmer installs local JTAG server and this solves all problems.. :)
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
