17268 Discussions
Can't launch the Modelsim-Altera Software after the compilation
My OS is Windows 7 64 bit. I'm using Quartus II 13.1 Web Edition, and Modelsim 10.1d. When I go Tools > Run Similation Tool > RTL Simulation; I get this Nativelink Error:
https://www.alteraforum.com/forum/attachment.php?attachmentid=9088
I checked Tools>Options>EDA Tool Options:
https://www.alteraforum.com/forum/attachment.php?attachmentid=9089
and this:
https://www.alteraforum.com/forum/attachment.php?attachmentid=9090
I tried to change and add the path: "\" or "\." but don't work.
Can someone help me?
possible idea => might be if you have spaces in your project directory
--- Quote Start ---
--- Quote End ---
I have this problem for all the projects I try to simulate and they are in differents directory.
this post might help, you might need a \ added to the path
http://www.alteraforum.com/forum/showthread.php?t=43012
Hello kchan,
Have you run at least the Analysis and Synthesis tool ?
Have you checked the log file ?
Can you run modelsim-altera outside the quartus enviroment ?
If I were you I would change the simulation directory in something like: simulation/modelsim instead of C:\altera\13.1\modelsim_ase\win32aloem
I try to re-install Quartus and Models in a different directory and now are both in folder Quartus-Modelsim and the path of simulation assigned is:
C:/Program Files/Quartus-Modelsim/modelsim_ase/win32aloem
but even after the re-installation and the change of directory I have SAME problem.
@kuppe I can launch the Analysis and Synthesis tool and it worked without problem.
I can open Modelsim program without problem but I don't know how lauch a run simulation not started by Quartus. I am a student and I am a very beginner of Quartus but I have to learn to simulate for my exam!
For the log file do you mean this?
--- Quote Start ---
Info: Start Nativelink Simulation process
Info: NativeLink has detected VHDL design -- VHDL simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : cyclonev
Quartus root : c:/program files/quartus-modelsim/quartus/bin64/
Quartus sim root : c:/program files/quartus-modelsim/quartus/eda/sim_lib
Simulation Tool : modelsim-altera
Simulation Language : vhdl
Version : 93
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation\modelsim
Info: Starting NativeLink simulation with ModelSim-Altera software
Sourced NativeLink script c:/program files/quartus-modelsim/quartus/common/tcl/internal/nativelink/modelsim.tcl
Error: Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path.
Error: You can specify the path in the EDA Tool Options page of the Options dialog box or using the Tcl command set_user_option.
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: issued_nl_message
Nativelink TCL script failed with errorInfo: Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path.
while executing
"error "$emsg" "" "issued_nl_message" "
(procedure "launch_sim" line 85)
invoked from within
"launch_sim launch_args_hash"
("eval" body line 1)
invoked from within
"eval launch_sim launch_args_hash"
invoked from within
"if [ info exists ::errorCode ] {
set savedCode $::errorCode
set savedInfo $::errorInfo
error $result $savedInfo $savedCode
} else {
invoked from within
"if [catch {eval launch_sim launch_args_hash} result ] {
set status 1
set sav..."
(procedure "run_sim" line 78)
invoked from within
"run_sim run_sim_args_hash"
invoked from within
error "$result" $savedInfo $savedCode
} else {
er..."
(procedure "run_eda_simulation_tool" line 330)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
--- Quote End ---
wolfram77
This path worked for me: C:/Program Files/Quartus-Modelsim/modelsim_ase/win32aloem
I am a student and learning to use this.
--- Quote Start ---
--- Quote End ---
Before open this thread I have already read that post and I already tried but for me that change but don't work.
Nobody can help me to fix this problem? I really need to simulate for my exam! :(
I solved this problem by putting an extra \ at the end of the path. i.e. C:\altera\13.1\modelsim_ase\win32aloem
Hopefully that is useful to someone.
Problem:
My OS is Windows 7 64 bit. I'm using Quartus II 15.0 Web Edition, and Modelsim 13.1d. I can't launch the Modsim-Altera software after the compilation and the compilation is no error and warning.
F:\program file(x86)\15.0\modsim_ase\win32aloem,I can't launch the ModelSim-Altera software. The path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path...
I trid to change and add the path:"\" or "/" and cut the modsim_ase files to outside of the program file(x86) files.but don't work.
The way of solving the problem:
The path:"F:\program file(x86)\15.0\modsim_ase\win32aloem" includes a blank space,in other words,program file(x86) contains a blank space or '(' and ')'.You should change the path:for example,
"F:\programfile\15.0\modsim_ase\win32aloem\",
"F:\altera\15.0\modsim_ase\win32aloem\",
"C:\altera\15.0\modsim_ase\win32aloem\
I try to re-install Quartus and Models in a directory and now are both in folder 15.0 and the path of simulation assigned is:
F:\altera\15.0\modsim_ase\win32aloem\".It does work!!!
note:
1.The install and project directory doesn't have blank space.
2.The default directory path is "C:\altera\15.0".You'd better only change the 'C' to 'F'or other disk.
Thanks for the sharing.
--- Quote Start ---
--- Quote End ---
This is something many not aware of !!
--- Quote Start ---
--- Quote End ---
Thanks for sharing your resolution.
