16723 Discussions
Cannot install Quartus Prime Lite 20.1
kevhua36
I am having trouble installing Quartus Prime Lite 20.1
I have downloaded the Quartus prime (includes Nios II EDS), the ModelSim, and max 10 FPGA device support. However, when I run the quartuslitesetup, it shows me the opening screen before closing.
I tried downloading the combined files and running setup.bat however the same thing happens.
Then I decided to follow some youtube videos online, where some videos run the other setups first (like the help), however, the same opening screens pop up before closing.
I tried deleting and reinstalling all these files again and even decided to go to a different version (20.1.1) of Quartus Prime Lite for the same thing to happen still.
What do I do? Any help would be appreciated.
sstrell
What is your computer setup (hardware, OS)?
I'd try downloading Quartus again.  Perhaps you have a corrupted download.
kevhua36
Im trying to download quartus on a lenovo thinkpad T470. Windows 10.
Don't think I have a corrupted download since I was able to download it on a different laptop (temporary) from the same source. (https://fpgasoftware.intel.com/20.1/?edition=lite&platform=windows)
EBERLAZARE_I_Intel
Did you uninstalled them correctly? Please check in control panel> uninstall program, and uninstall them and reinstall.
Alternatively, if possible you could try to download on another PC to see if the installation would be successful there.
kevhua36
I have never installed Quartus in the beginning so there was no way I could uninstall anyways.
As for downloading on another PC, I was able to download it on a temporary laptop which was a Lenovo Thinkpad T450.
EBERLAZARE_I_Intel
Can you also install Quartus on that temporary laptop?
Is this your personal laptop or working laptop that the installation was not working?
kevhua36
I can download quartus on my temporary laptop but not on my personal laptop as the installer won't work.
EBERLAZARE_I_Intel
Did you try to install in the temporary laptop? Did it work there?
Can you try a different version?
noahelec
Is this problem solved? Same thing happened to me.
Jinwhuh
Is there a solution to this problem? The same thing keeps happening to me and I've tried everything.
noahelec
Hi, I had the same problem and ended up downloading different version (22.1) and it worked perfectly.ㅏ
