17266 Discussions
Concatenation in VHDL
I have a question and maybe you can help me. I am writing a code in VHDL and I came across the following problem:
I have a four-bit input, ranging from 0 to 9 with time, called "Hundreds" and need to concatenate it with the following string: "100011". I wonder if the following code snippet work:
"100011"&hundreds;
If you do not work, how do I solve this problem?
Thank you
Without seeing the full code, we will have no idea. Why not try some code and compiling it?
Sorry... Below is the code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY dados_lcd IS
PORT(
clk : IN STD_LOGIC; --system clock
hundreds : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
tens : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
unit : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
rw, rs, e : OUT STD_LOGIC; --read/write, setup/data, and enable for lcd
lcd_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); --data signals for lcd
END dados_lcd;
ARCHITECTURE behavioral OF dados_lcd IS
SIGNAL lcd_enable : STD_LOGIC;
SIGNAL lcd_bus : STD_LOGIC_VECTOR(9 DOWNTO 0);
SIGNAL lcd_busy : STD_LOGIC;
COMPONENT lcd_controller IS
PORT(
reset_n : IN STD_LOGIC; --active low reinitializes lcd
lcd_enable : IN STD_LOGIC; --latches data into lcd controller
lcd_bus : IN STD_LOGIC_VECTOR(9 DOWNTO 0); --data and control signals
busy : OUT STD_LOGIC; --lcd controller busy/idle feedback
END COMPONENT;
BEGIN
--instanciando o lcd_controller
dados: lcd_controller
PORT MAP(clk => clk,
reset_n => '1',
lcd_enable => lcd_enable,
lcd_bus => lcd_bus,
busy => lcd_busy,
rw => rw,
rs => rs,
e => e,
lcd_data => lcd_data
PROCESS(clk, hundreds, tens, unit)
VARIABLE char : INTEGER RANGE 0 TO 25 := 0;
BEGIN
IF(clk'EVENT AND clk = '1') THEN
IF(lcd_busy = '0' AND lcd_enable = '0') THEN
lcd_enable <= '1';
IF(char < 25) THEN
char := char + 1;
END IF;
CASE char IS
WHEN 1 => lcd_bus <= "1001000100"; --D
WHEN 2 => lcd_bus <= "1001001001"; --I
WHEN 3 => lcd_bus <= "1001010011"; --S
WHEN 4 => lcd_bus <= "1001010100"; --T
WHEN 5 => lcd_bus <= "1010110110"; --
WHEN 6 => lcd_bus <= "1001001110"; --N
WHEN 7 => lcd_bus <= "1001000011"; --C
WHEN 8 => lcd_bus <= "1001001001"; --I
WHEN 9 => lcd_bus <= "1001000001"; --A
WHEN 10 => lcd_bus <= "1000111010"; --:
WHEN 11 => lcd_bus <= "0011000000"; --Command (cursor primeira posição da segunda linha)
WHEN 12 => lcd_bus <= "1000100000"; --SPC
WHEN 13 => lcd_bus <= "1000100000"; --SPC
WHEN 14 => lcd_bus <= "1000100000"; --SPC
WHEN 15 => lcd_bus <= "1000100000"; --SPC
WHEN 16 => lcd_bus <= "1000100000"; --SPC
WHEN 17 => lcd_bus <= "1000100000"; --SPC
WHEN 18 => lcd_bus <= "1000100000"; --SPC
WHEN 19 => lcd_bus <= "1000100000"; --SPC
WHEN 20 => lcd_bus <= "1000100000"; --SPC
WHEN 21 => lcd_bus <= "1000100000"; --SPC
WHEN 22 => lcd_bus <= "100011"&hundreds; --centenas
WHEN 23 => lcd_bus <= "100011"&tens; --dezenas
WHEN 24 => lcd_bus <= "100011"&unit; --unidades
WHEN OTHERS => lcd_enable <= '0';
END CASE;
ELSE
lcd_enable <= '0';
END IF;
END IF;
END PROCESS;
END behavioral;
And whats the problem?
My question is whether it is right to do the following:
"100011"&hundreds
When "Hundreds" equals "1001", the result will be: "100011"&"1001" = "1000111001" ?
These kind of questions can quickly and easily be checked with a compiler and simulator (quicker than using a forum)
Yes, this is exactly how it works.
Ok, thank you and apologize for the inconvenience.
You can try using Modelsim Altera Starter edition which is free to simulation the functional behavior of your logic.
