- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I have a question and maybe you can help me. I am writing a code in VHDL and I came across the following problem: I have a four-bit input, ranging from 0 to 9 with time, called "Hundreds" and need to concatenate it with the following string: "100011". I wonder if the following code snippet work: "100011"&hundreds; If you do not work, how do I solve this problem? Thank youLien copié
7 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Without seeing the full code, we will have no idea. Why not try some code and compiling it?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Sorry... Below is the code:
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY dados_lcd IS PORT( clk : IN STD_LOGIC; --system clock hundreds : IN STD_LOGIC_VECTOR(3 DOWNTO 0); tens : IN STD_LOGIC_VECTOR(3 DOWNTO 0); unit : IN STD_LOGIC_VECTOR(3 DOWNTO 0); rw, rs, e : OUT STD_LOGIC; --read/write, setup/data, and enable for lcd lcd_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); --data signals for lcd END dados_lcd; ARCHITECTURE behavioral OF dados_lcd IS SIGNAL lcd_enable : STD_LOGIC; SIGNAL lcd_bus : STD_LOGIC_VECTOR(9 DOWNTO 0); SIGNAL lcd_busy : STD_LOGIC; COMPONENT lcd_controller IS PORT( clk : IN STD_LOGIC; --system clock reset_n : IN STD_LOGIC; --active low reinitializes lcd lcd_enable : IN STD_LOGIC; --latches data into lcd controller lcd_bus : IN STD_LOGIC_VECTOR(9 DOWNTO 0); --data and control signals busy : OUT STD_LOGIC; --lcd controller busy/idle feedback rw, rs, e : OUT STD_LOGIC; --read/write, setup/data, and enable for lcd lcd_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); --data signals for lcd END COMPONENT; BEGIN --instanciando o lcd_controller dados: lcd_controller PORT MAP(clk => clk, reset_n => '1', lcd_enable => lcd_enable, lcd_bus => lcd_bus, busy => lcd_busy, rw => rw, rs => rs, e => e, lcd_data => lcd_data ); PROCESS(clk, hundreds, tens, unit) VARIABLE char : INTEGER RANGE 0 TO 25 := 0; BEGIN IF(clk'EVENT AND clk = '1') THEN IF(lcd_busy = '0' AND lcd_enable = '0') THEN lcd_enable <= '1'; IF(char < 25) THEN char := char + 1; END IF; CASE char IS WHEN 1 => lcd_bus <= "1001000100"; --D WHEN 2 => lcd_bus <= "1001001001"; --I WHEN 3 => lcd_bus <= "1001010011"; --S WHEN 4 => lcd_bus <= "1001010100"; --T WHEN 5 => lcd_bus <= "1010110110"; --Â WHEN 6 => lcd_bus <= "1001001110"; --N WHEN 7 => lcd_bus <= "1001000011"; --C WHEN 8 => lcd_bus <= "1001001001"; --I WHEN 9 => lcd_bus <= "1001000001"; --A WHEN 10 => lcd_bus <= "1000111010"; --: WHEN 11 => lcd_bus <= "0011000000"; --Command (cursor primeira posição da segunda linha) WHEN 12 => lcd_bus <= "1000100000"; --SPC WHEN 13 => lcd_bus <= "1000100000"; --SPC WHEN 14 => lcd_bus <= "1000100000"; --SPC WHEN 15 => lcd_bus <= "1000100000"; --SPC WHEN 16 => lcd_bus <= "1000100000"; --SPC WHEN 17 => lcd_bus <= "1000100000"; --SPC WHEN 18 => lcd_bus <= "1000100000"; --SPC WHEN 19 => lcd_bus <= "1000100000"; --SPC WHEN 20 => lcd_bus <= "1000100000"; --SPC WHEN 21 => lcd_bus <= "1000100000"; --SPC WHEN 22 => lcd_bus <= "100011"&hundreds; --centenas WHEN 23 => lcd_bus <= "100011"&tens; --dezenas WHEN 24 => lcd_bus <= "100011"&unit; --unidades WHEN OTHERS => lcd_enable <= '0'; END CASE; ELSE lcd_enable <= '0'; END IF; END IF; END PROCESS; END behavioral;- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
And whats the problem?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
My question is whether it is right to do the following:
"100011"&hundreds When "Hundreds" equals "1001", the result will be: "100011"&"1001" = "1000111001" ? Thanks- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
These kind of questions can quickly and easily be checked with a compiler and simulator (quicker than using a forum)
Yes, this is exactly how it works.- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Ok, thank you and apologize for the inconvenience.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
You can try using Modelsim Altera Starter edition which is free to simulation the functional behavior of your logic.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
