17267 Discussions
Control SRAM On DE2-115
BBBBo15
Hi, I am trying to read and write a buffer on an FPGA, and I want to use SRAM to read and write this buffer. However, I have tried two different methods, but I still couldn't get the SRAM to correctly read (or write) the buffer data.
The first method is using a simple arbitration module written in Verilog. The code is in attachment.
Regarding the inout connections, I wrote them according to the example in the SD Card Music Player ip\TERASIC_SRAM\TERASIC_SRAM.v. I also tried writing them in reverse:
assign sram_dq = sram_we_reg? render_dq : 16'hz;
However, the result is still incorrect.
The second method is using the IP core SRAM Controller, screenshots are in the attachments.
I also used Signal Tap Logic Analyzer to observe the data after downloading it to the FPGA, and the screenshots are also in the attachments(readdata[15..0] line).
The problem now is, regardless of the method used, how can I correctly read and write the buffer in the SRAM? Of course, if you can correct the problems in the code, that would be even better. Thank you!
Software: Quartus Prime 20.1 Lite Edition
FPGA: DE2-115
AdzimZM_Intel
May I know which design that you're used to do the testing?
  • Is it you own design or Intel design example?
Do you check if the design is passing timing analysis?
Is the pin location has been assigned correctly based on the board?
Adzim
BBBBo15
Hi Adzim,
It's my own design.
It says "Quartus Prime Timing Analyzer was successful. 0 errors, 24 warnings".
In compilation report, Timing Analyzer/ Unconstrained Paths/Summary, and ../Clock Status Summary is in red color.
sorry if i misunderstood it and Time Analyzer, i haven't use Time Analyzer yet.
yes, all pins are assigned correctly in Pin Planner
Thank you.
BBBBo15
Hi Adzim,
It's my own design.
Thank you.
sstrell
Well, this is certainly correct for a bidi so your attached file is wrong: assign sram_dq = sram_we_reg? render_dq : 16'hz;
And your design is not constrained for timing.  You need to create a .sdc file and constrain those clocks and the I/O.  User guide is here: https://www.intel.com/content/www/us/en/docs/programmable/683068/18-1/timing-analysis-introduction.html
AdzimZM_Intel
Have you put create the timing constraint as suggested by sstrell?
Adzim
BBBBo15
Sorry, no.
The FPGA belongs to my school, and this is my graduation project. Recently, I was working on the rendering module to ensure its functionality. After the graduation project evaluation was completed, the FPGA was returned to the school, so I did not have time to try Time Analyzer.
And the solution I used was to complete the read and write functionality using the on chip memory.
Thank you and sstrell for the advise.
