17268 Discussions
Create an IP like the Qsys Clock Source
DWang108
1 why ClockSourceIP can export clk & reset automatic
2 why NOT ClockSourceIP connect clock signal itself
but ClockBridgeIP try to connect clk loop to itself
3 I want to create an IP which behave like the ClockSource
may I have some tcl sample to do that
thx
David Wang
xinqiang_wang@yahoo.com
RichardTanSY_Altera
Clock Source is a clock output interface that drives a clock signal out of a component. Clock output interfaces cannot have reset signals.
Its clock input interfaces provide synchronization control for a component. A typical component has a clock input to provide a timing reference for other interfaces and internal logic.
Reference:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-platform-designer.pdf#page=161
Clock bridge allows you to route between Qsys subsystems. The Clock Bridge connects a clock source to multiple clock input interfaces. You can use the clock bridge to connect a clock source that is outside the Platform Designer system. Create the connection through an exported interface, and then connect to multiple clock input interfaces.
Reference:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-platform-designer.pdf#page=212
You can refer to the Quartus scripting manual regarding clock source tcl scripting information.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/tclscriptrefmnl.pdf
