17257 Discussions
Created bootloader for CycloneV SOC doesn't work
Sperber
I'm currently trying to follow up several tutorials on creating a preloader and bootloader for an Intel Cyclone V Soc. For example I did all steps from this tutorial:
https://www.youtube.com/watch?v=vS7pvefsbRM
After creating the preloader and bootloader in EDS Command Shell ("make" and "make uboot")
I transfer it to the FAT partition on my SD card drive G:
( "alt-boot-disk-util.exe -p preloader-mkpimage.bin -a write -d g"   and "cp uboot-socfpga/u-boot.img /cygdrive/g")
But when I put the card into the Terassic DE 10 Nano Board it will not boot.
I see the following output in Putty:
U-Boot SPL 2013.01.01 (Oct 06 2020 - 09:13:30)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 3125 KHz
RESET: WARM
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
ALTERA DWMMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.01.01 (Oct 06 2020 - 09:22:09)
CPU   : Altera SOCFPGA Platform
I2C:   ready
DRAM:  1 GiB
MMC:   ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net:   mii0
Warning: failed to set MAC address
Hit any key to stop autoboot:  5  4  3  2  1  0
reading u-boot.scr
** Unable to read file u-boot.scr **
Optional boot script not found. Continuing to boot normally
reading zImage
** Unable to read file zImage **
reading socfpga.dtb
** Unable to read file socfpga.dtb **
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SOCFPGA_CYCLONE5 #
I checked all steps but I didn't find the issue.
Can someone help me?
Thank you very much.
Sperber
I now tried to do the steps in Ubuntu 18.04 instead of Win 10  but I still got the same issue.
Does anybody have this kind of problems also?
Thank you
EBERLAZARE_I_Intel
Please refer to our tutorial, guidelines and document below:
https://rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD
