17244 討論
Cyclone IV EP4CE10F17C8N Chip: Light LED
榮譽貢獻者 II
3,009 檢視
Hello All,
This is my first time using an FPGA, my independent research is currently using the book "RTL Hardware Design Using VHDL" by Pong Chu.
I have purchased an Altera Cyclone IV with a EP4CE10F17C8N chip. I am programming using Quartis Prime Lite, in VHDL. I am programing the board with a USB Blaster, all drivers installed.
My aim was to test a simple code by turning on an on-board LED. I do not see anything wrong with the VHDL Code and I have no compilation error, yet I do not see any LED turned on (aside from the power LED). This leads me to belive it may be the pin assignment.
I am using the following data sheet:
https://www.waveshare.com/w/upload/c/c8/coreep4ce10-schematic.pdf
(https://www.waveshare.com/w/upload/c/c8/coreep4ce10-schematic.pdf
And assigned LED to PIN_D12
My Code is as follows:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; ENTITY light IS PORT(--X1 : IN STD_LOGIC; LED : OUT STD_LOGIC := '0' ); END light; ARCHITECTURE LogicFunction OF light IS BEGIN LED <= '1'; END LogicFunction;
I am not sure why I can not light the LED, any help will be much appreciated. Thank you in advance!
0 積分
3 回應
榮譽貢獻者 II
1,678 檢視
From schematic LED will turn on when you assign LED <= '0' and will turn of when LED <= '1'.
榮譽貢獻者 II
1,678 檢視
Yes, the LED is active low.
榮譽貢獻者 II
1,678 檢視
--- Quote Start ---
--- Quote End ---
Got it, thank you all! So I was able to light the LED knowing it is active LOW. I.e. I changed LED <= '1'; to a 0.
Thanks again!
回覆
