17268 Discussions
DDR3 memory controller
zx71769
Quartus version: 18.1
When I include ddr3 controller IP in my design and compiler . I got some error information below:
332000 ERROR: Argument <node_object> is an object filter that matches no objects. Specify one matches only one object.
while executing
"get_node_info -cell $node_id"
  (procedure "mem_ip_0319_p0_is_node_type_pll_clk" line 2)
  invoked from within
"mem_ip_0319_p0_is_node_type_pll_clk $pll_output_node_id"
(procedure "mem_ip_0319_p0_get_input_clk_id" line 2)
  invoked from within
"mem_ip_0319_p0_get_input_clk_id $pll_ck_clock_id"
(procedure "mem_ip_0319_p0_get_ddr_pins" line 257)
  invoked from within
"mem_ip_0319_p0_get_ddr_pins $instname allpins"
(procedure "mem_ip_0319_p0_initialize_ddr_db" line 13)
  invoked from within
"mem_ip_0319_p0_initialize_ddr_db mem_ip_0319_p0_ddr_db"
  invoked from within
"if { ! [ info exists mem_ip_0319_p0_sdc_cache] } {
  set mem_ip_0319_p0_sdc_cache 1
}else{
    (file "mem_ip_0319/mem_ip_0319/mem_ip_0319_p0.sdc" line 146)
174068 Output buffer atom "<ip_node>" has port "SERIESTERMINATIONCONTROL[0]" connected, but does not use calibrated on-chip ...
so I google it.
I try to source tcl file (ip_name_p0_pin_assignments.tcl)
but I got same error like below link.
https://community.intel.com/t5/FPGA-Intellectual-Property/Error-when-running-pin-assignment-tcl-script/td-p/208965
How can I fix it. Thanks for help !!
zx71769
At first,I tried to instance 4 ddr memory controller. It cannot work like I posted before. So I tried to just instance one ddr3 memory controller. And I source XXX0_pin_assignment.tcl and compiler again. It will be OK. No any error appear until the end. So I decide to use GUI to produce 2 ddr3 memory controller again. And   I source XXX0_pin_assignment.tcl ,  XXX1_pin_assignment.tcl. But when I source the second tcl(XXX1_pin_assignment.tcl). It appear error like before. Am I wrong?  Thanks for help.
