16975 Discussions
DE-series board pin assignment for Cyclone 10
LChow3
I don't have the hardware DE-series board. But I like to learn about how to configure it using Quartus Prime. I have downloaded Cyclone 10 since it's free. Or which device family shall I use?
Where can get the DE-series board pin assignment for Cyclone 10?
In the Assignment Editor, I need to key in the Value for each pins. How shall I do that?
Thank you.
Deshi_Intel
HI,
I presume you are new Quartus user. Pls see my reply below.
  1. which device family shall I use ?
  • This will depends on which board that you plans to use and which intel FPGA is soldered on the board.
    • After that, you can then create Quartus project specifying exact FPGA part number that matched with FPGA used on the dev kit board.
  1. Where can get the DE-series board pin assignment for Cyclone 10 ?
  • Again, it depends on which dev kit board that you plans to use first.
    • After that, you can google for that dev kit website. The website will contains either user guide manual doc or board schematic file that show you the pin assignment
  1. In the Assignment Editor, I need to key in the Value for each pins. How shall I do that ?
dlim
LChow3
Deshi_Intel
welcome !
Alright, I will be setting this case to closure.
Feel free to file new forum thread if you still have enquiry in future.
dlim
