17249 Discussions
DE2-115 media computer verilog top level entity to VHDL
For my project I'm using a DE2-115 board with the media computer. I want to edit the given verilog top-level entity from the university programs but I have no experience with Verilog, but I do have experience with VHDL. Now my question is: is there a way to convert the verilog file to VHDL, or has someone already done it?
In the university programs there is no VHDL version, only a verilog version.
This is the verilog code:
module DE2_115_Media_Computer ( // Inputs CLOCK_50, CLOCK2_50, CLOCK3_50, TD_CLK27, KEY, SW, // Communication UART_RXD, // Audio AUD_ADCDAT, // IrDA IRDA_RXD, // Video In TD_DATA, TD_HS, TD_VS, // USB OTG_INT, /*****************************************************************************/ // Bidirectionals GPIO, // Memory (SRAM) SRAM_DQ, // Memory (SDRAM) DRAM_DQ, // PS2 Port PS2_KBCLK, PS2_KBDAT, PS2_MSCLK, PS2_MSDAT, // Audio AUD_BCLK, AUD_ADCLRCK, AUD_DACLRCK, // Char LCD 16x2 LCD_DATA, // AV Config I2C_SDAT, // SD Card SD_CMD, SD_DAT, // Flash FL_DQ, //USB OTG_DATA, /*****************************************************************************/ // Outputs // Simple LEDG, LEDR, HEX0, HEX1, HEX2, HEX3, HEX4, HEX5, HEX6, HEX7, // Memory (SRAM) SRAM_ADDR, SRAM_CE_N, SRAM_WE_N, SRAM_OE_N, SRAM_UB_N, SRAM_LB_N, // Communication UART_TXD, // Memory (SDRAM) DRAM_ADDR, DRAM_BA, DRAM_CAS_N, DRAM_RAS_N, DRAM_CLK, DRAM_CKE, DRAM_CS_N, DRAM_WE_N, DRAM_DQM, // Audio AUD_XCK, AUD_DACDAT, // VGA VGA_CLK, VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N, VGA_R, VGA_G, VGA_B, // Char LCD 16x2 LCD_ON, LCD_BLON, LCD_EN, LCD_RS, LCD_RW, // AV Config I2C_SCLK, // SD Card SD_CLK, // Flash FL_ADDR, FL_CE_N, FL_OE_N, FL_RESET_N, FL_WE_N, // Video In TD_RESET_N, // USB OTG_ADDR, OTG_CS_N, OTG_OE_N, OTG_RST_N, OTG_WE_N, ); /***************************************************************************** * Parameter Declarations * *****************************************************************************/ /***************************************************************************** * Port Declarations * *****************************************************************************/ // Inputs input CLOCK_50; input CLOCK2_50; input CLOCK3_50; input TD_CLK27; input KEY; input SW; // Communication input UART_RXD; // Audio input AUD_ADCDAT; // IrDA input IRDA_RXD; // Video In input TD_DATA; input TD_HS; input TD_VS; // USB input OTG_INT; // Bidirectionals inout GPIO; // Memory (SRAM) inout SRAM_DQ; // Memory (SDRAM) inout DRAM_DQ; // PS2 Port inout PS2_KBCLK; inout PS2_KBDAT; inout PS2_MSCLK; inout PS2_MSDAT; // Audio inout AUD_BCLK; inout AUD_ADCLRCK; inout AUD_DACLRCK; // AV Config inout I2C_SDAT; // Char LCD 16x2 inout LCD_DATA; // SD Card inout SD_CMD; inout SD_DAT; // Flash inout FL_DQ; // USB inout OTG_DATA; // Outputs output TD_RESET_N; // Simple output LEDG; output LEDR; output HEX0; output HEX1; output HEX2; output HEX3; output HEX4; output HEX5; output HEX6; output HEX7; // Memory (SRAM) output SRAM_ADDR; output SRAM_CE_N; output SRAM_WE_N; output SRAM_OE_N; output SRAM_UB_N; output SRAM_LB_N; // Communication output UART_TXD; // Memory (SDRAM) output DRAM_ADDR; output DRAM_BA; output DRAM_CAS_N; output DRAM_RAS_N; output DRAM_CLK; output DRAM_CKE; output DRAM_CS_N; output DRAM_WE_N; output DRAM_DQM; // Audio output AUD_XCK; output AUD_DACDAT; // VGA output VGA_CLK; output VGA_HS; output VGA_VS; output VGA_BLANK_N; output VGA_SYNC_N; output VGA_R; output VGA_G; output VGA_B; // Char LCD 16x2 output LCD_ON; output LCD_BLON; output LCD_EN; output LCD_RS; output LCD_RW; // AV Config output I2C_SCLK; // SD Card output SD_CLK; // Flash output FL_ADDR; output FL_CE_N; output FL_OE_N; output FL_RESET_N; output FL_WE_N; //USB output OTG_ADDR; output OTG_CS_N; output OTG_OE_N; output OTG_RST_N; output OTG_WE_N; /***************************************************************************** * Internal Wires and Registers Declarations * *****************************************************************************/ // Internal Wires // Internal Registers // State Machine Registers /***************************************************************************** * Finite State Machine(s) * *****************************************************************************/ /***************************************************************************** * Sequential Logic * *****************************************************************************/ /***************************************************************************** * Combinational Logic * *****************************************************************************/ // Output Assignments assign GPIO = 1'bZ; assign GPIO = 1'bZ; assign GPIO = 1'bZ; assign GPIO = 1'bZ; /***************************************************************************** * Internal Modules * *****************************************************************************/ nios_system NiosII ( // 1) global signals: .system_pll_ref_clk_clk (CLOCK_50), .system_pll_ref_reset_reset (~KEY), .sdram_clk_clk (DRAM_CLK), // SDRAM .sdram_addr (DRAM_ADDR), .sdram_ba (DRAM_BA), .sdram_cas_n (DRAM_CAS_N), .sdram_cke (DRAM_CKE), .sdram_cs_n (DRAM_CS_N), .sdram_dq (DRAM_DQ), .sdram_dqm (DRAM_DQM), .sdram_ras_n (DRAM_RAS_N), .sdram_we_n (DRAM_WE_N), // SRAM .sram_DQ (SRAM_DQ), .sram_ADDR (SRAM_ADDR), .sram_LB_N (SRAM_LB_N), .sram_UB_N (SRAM_UB_N), .sram_CE_N (SRAM_CE_N), .sram_OE_N (SRAM_OE_N), .sram_WE_N (SRAM_WE_N), // SD Card .sd_card_b_SD_cmd (SD_CMD), .sd_card_b_SD_dat (SD_DAT), .sd_card_b_SD_dat3 (SD_DAT), .sd_card_o_SD_clock (SD_CLK), // Flash .flash_ADDR (FL_ADDR), .flash_CE_N (FL_CE_N), .flash_OE_N (FL_OE_N), .flash_WE_N (FL_WE_N), .flash_RST_N (FL_RESET_N), .flash_DQ (FL_DQ), // Red LEDs .red_leds_export (LEDR), // Green LEDs .green_leds_export (LEDG), // HEX3 HEX0 .hex3_hex0_HEX0 (HEX0), .hex3_hex0_HEX1 (HEX1), .hex3_hex0_HEX2 (HEX2), .hex3_hex0_HEX3 (HEX3), // HEX7 HEX4 .hex7_hex4_HEX4 (HEX4), .hex7_hex4_HEX5 (HEX5), .hex7_hex4_HEX6 (HEX6), .hex7_hex4_HEX7 (HEX7), // Slider switches .slider_switches_export (SW), // Pushbuttons .pushbuttons_export ({KEY, 1'b1}), // Expansion JP5 .expansion_jp5_export ({GPIO, GPIO, GPIO, GPIO}), // PS2 Port .ps2_port_CLK (PS2_KBCLK), .ps2_port_DAT (PS2_KBDAT), // PS2 Port Dual .ps2_port_dual_CLK (PS2_MSCLK), .ps2_port_dual_DAT (PS2_MSDAT), // USB .usb_INT1 (OTG_INT), .usb_DATA (OTG_DATA), .usb_RST_N (OTG_RST_N), .usb_ADDR (OTG_ADDR), .usb_CS_N (OTG_CS_N), .usb_RD_N (OTG_OE_N), .usb_WR_N (OTG_WE_N), .usb_INT0 (OTG_INT), // Serial port .serial_port_RXD (UART_RXD), .serial_port_TXD (UART_TXD), // IRDA .irda_TXD (), .irda_RXD (IRDA_RXD), // AV Config .av_config_SDAT (I2C_SDAT), .av_config_SCLK (I2C_SCLK), // VGA Subsystem .vga_CLK (VGA_CLK), .vga_HS (VGA_HS), .vga_VS (VGA_VS), .vga_BLANK (VGA_BLANK_N), .vga_SYNC (VGA_SYNC_N), .vga_R (VGA_R), .vga_G (VGA_G), .vga_B (VGA_B), .vga_pll_ref_clk_clk (CLOCK2_50), .vga_pll_ref_reset_reset (~KEY), // Audio Subsystem .audio_pll_ref_clk_clk (CLOCK3_50), .audio_pll_ref_reset_reset (~KEY), .audio_clk_clk (AUD_XCK), .audio_ADCDAT (AUD_ADCDAT), .audio_BCLK (AUD_BCLK), .audio_ADCLRCK (AUD_ADCLRCK), .audio_DACLRCK (AUD_DACLRCK), .audio_DACDAT (AUD_DACDAT), // Character LCD 16x2 .char_lcd_DATA (LCD_DATA), .char_lcd_ON (LCD_ON), .char_lcd_BLON (LCD_BLON), .char_lcd_EN (LCD_EN), .char_lcd_RS (LCD_RS), .char_lcd_RW (LCD_RW), // Video In Subsystem .video_in_TD_CLK27 (TD_CLK27), .video_in_TD_DATA (TD_DATA), .video_in_TD_HS (TD_HS), .video_in_TD_VS (TD_VS), .video_in_TD_RESET (TD_RESET_N), .video_in_clk27_reset (~KEY), .video_in_overflow_flag () ); endmodule
That top level is little more than a port map. Plus Quartus supports mixed language. So why bother re-writing it to VHDL?
--- Quote Start ---
--- Quote End ---
As I said, I want to edit the given verilog. I could add a VHDL file that has a DE2_115_Media_Computer component but i'd rather not retype all those inputs and outputs to VHDL since that would take a long time. I was just wondering if someone else has already converted this or if there is an automated way to convert verilog to VHDL. If someone has a DE2_115_Media_Computer component with a port map and an entity that'd be great too.
If you dont find it - then maybe its a good time to learn verilog. If you already know VHDL then Verilog is pretty easy to understand and write.
For people who may have the same issue, I've added a port map from the verilog file to my VHDL file.
