17268 Discussions
Is there an Editor in Platform Designer?
If I wanted to edit/create some custom IP, that is going to be included in a Qsys-project, is there any way to edit the VHDL of a file from within Platform Designer?
I know I can define the wrapper with its ports/conduits etc, but to actually add more VHDL inside, I currently need to use a 3rd party text editor.
The irony is that if you open the file (post synthesis) from the Quartus Project navigator, you get the copied-version in the ../project_name/submodules/ folder...why?
1.Why can't you write a logic and then create a custom IP?
--- Quote Start ---
--- Quote End ---
No, can't edit/add the logic by using platform designer for the custom component.
--- Quote Start ---
--- Quote End ---
Why use 3rd party either you can use Quartus itself. You first create a wrapper and then add logic and compile the design and use it.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
I use a 3rd party editor because I can set my editor to always look for my files in their source directory.
If you use the Project Navigator to open a file, Quartus opens the copied version of the file, not the source.
Is there a way to change this?
Have you set Preferred Text Editor in Quartus?
Form tools->options->Preferred Text Editor.
Select text editor of you choice and command-line point to .exe file.
If still quartus opens copied version of the file check the text editor settings.
I have used Notepad++ and opened the file from quartus it opens the source file only.
Anand Raj Shankar
If you go to the Files tab of the Project Navigator, instead of the Hierarchy tab, you can double-click a source file to open and edit it.
However, for a custom component in Platform Designer, what you're seeing in the Project Navigator is the generated output of Platform Designer since you added this as a custom component to a system. That's why the original source file is not opening from the Project Navigator; Quartus sees the generated output, which is a copy of the original.
The only sure way to open the source for editing is to do File -> Open. You'll still have to regenerate the _hw.tcl file and the system anyway.
