- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
For my project I'm using a DE2-115 board with the media computer. I want to edit the given verilog top-level entity from the university programs but I have no experience with Verilog, but I do have experience with VHDL. Now my question is: is there a way to convert the verilog file to VHDL, or has someone already done it?
In the university programs there is no VHDL version, only a verilog version. This is the verilog code:
module DE2_115_Media_Computer (
// Inputs
CLOCK_50,
CLOCK2_50,
CLOCK3_50,
TD_CLK27,
KEY,
SW,
// Communication
UART_RXD,
// Audio
AUD_ADCDAT,
// IrDA
IRDA_RXD,
// Video In
TD_DATA,
TD_HS,
TD_VS,
// USB
OTG_INT,
// Bidirectionals
GPIO,
// Memory (SRAM)
SRAM_DQ,
// Memory (SDRAM)
DRAM_DQ,
// PS2 Port
PS2_KBCLK,
PS2_KBDAT,
PS2_MSCLK,
PS2_MSDAT,
// Audio
AUD_BCLK,
AUD_ADCLRCK,
AUD_DACLRCK,
// Char LCD 16x2
LCD_DATA,
// AV Config
I2C_SDAT,
// SD Card
SD_CMD,
SD_DAT,
// Flash
FL_DQ,
//USB
OTG_DATA,
// Outputs
// Simple
LEDG,
LEDR,
HEX0,
HEX1,
HEX2,
HEX3,
HEX4,
HEX5,
HEX6,
HEX7,
// Memory (SRAM)
SRAM_ADDR,
SRAM_CE_N,
SRAM_WE_N,
SRAM_OE_N,
SRAM_UB_N,
SRAM_LB_N,
// Communication
UART_TXD,
// Memory (SDRAM)
DRAM_ADDR,
DRAM_BA,
DRAM_CAS_N,
DRAM_RAS_N,
DRAM_CLK,
DRAM_CKE,
DRAM_CS_N,
DRAM_WE_N,
DRAM_DQM,
// Audio
AUD_XCK,
AUD_DACDAT,
// VGA
VGA_CLK,
VGA_HS,
VGA_VS,
VGA_BLANK_N,
VGA_SYNC_N,
VGA_R,
VGA_G,
VGA_B,
// Char LCD 16x2
LCD_ON,
LCD_BLON,
LCD_EN,
LCD_RS,
LCD_RW,
// AV Config
I2C_SCLK,
// SD Card
SD_CLK,
// Flash
FL_ADDR,
FL_CE_N,
FL_OE_N,
FL_RESET_N,
FL_WE_N,
// Video In
TD_RESET_N,
// USB
OTG_ADDR,
OTG_CS_N,
OTG_OE_N,
OTG_RST_N,
OTG_WE_N,
* Parameter Declarations *
* Port Declarations *
// Inputs
input CLOCK_50;
input CLOCK2_50;
input CLOCK3_50;
input TD_CLK27;
input KEY;
input SW;
// Communication
input UART_RXD;
// Audio
input AUD_ADCDAT;
// IrDA
input IRDA_RXD;
// Video In
input TD_DATA;
input TD_HS;
input TD_VS;
// USB
input OTG_INT;
// Bidirectionals
inout GPIO;
// Memory (SRAM)
inout SRAM_DQ;
// Memory (SDRAM)
inout DRAM_DQ;
// PS2 Port
inout PS2_KBCLK;
inout PS2_KBDAT;
inout PS2_MSCLK;
inout PS2_MSDAT;
// Audio
inout AUD_BCLK;
inout AUD_ADCLRCK;
inout AUD_DACLRCK;
// AV Config
inout I2C_SDAT;
// Char LCD 16x2
inout LCD_DATA;
// SD Card
inout SD_CMD;
inout SD_DAT;
// Flash
inout FL_DQ;
// USB
inout OTG_DATA;
// Outputs
output TD_RESET_N;
// Simple
output LEDG;
output LEDR;
output HEX0;
output HEX1;
output HEX2;
output HEX3;
output HEX4;
output HEX5;
output HEX6;
output HEX7;
// Memory (SRAM)
output SRAM_ADDR;
output SRAM_CE_N;
output SRAM_WE_N;
output SRAM_OE_N;
output SRAM_UB_N;
output SRAM_LB_N;
// Communication
output UART_TXD;
// Memory (SDRAM)
output DRAM_ADDR;
output DRAM_BA;
output DRAM_CAS_N;
output DRAM_RAS_N;
output DRAM_CLK;
output DRAM_CKE;
output DRAM_CS_N;
output DRAM_WE_N;
output DRAM_DQM;
// Audio
output AUD_XCK;
output AUD_DACDAT;
// VGA
output VGA_CLK;
output VGA_HS;
output VGA_VS;
output VGA_BLANK_N;
output VGA_SYNC_N;
output VGA_R;
output VGA_G;
output VGA_B;
// Char LCD 16x2
output LCD_ON;
output LCD_BLON;
output LCD_EN;
output LCD_RS;
output LCD_RW;
// AV Config
output I2C_SCLK;
// SD Card
output SD_CLK;
// Flash
output FL_ADDR;
output FL_CE_N;
output FL_OE_N;
output FL_RESET_N;
output FL_WE_N;
//USB
output OTG_ADDR;
output OTG_CS_N;
output OTG_OE_N;
output OTG_RST_N;
output OTG_WE_N;
* Internal Wires and Registers Declarations *
// Internal Wires
// Internal Registers
// State Machine Registers
* Finite State Machine(s) *
* Sequential Logic *
* Combinational Logic *
// Output Assignments
assign GPIO = 1'bZ;
assign GPIO = 1'bZ;
assign GPIO = 1'bZ;
assign GPIO = 1'bZ;
* Internal Modules *
nios_system NiosII (
// 1) global signals:
.system_pll_ref_clk_clk (CLOCK_50),
.system_pll_ref_reset_reset (~KEY),
.sdram_clk_clk (DRAM_CLK),
// SDRAM
.sdram_addr (DRAM_ADDR),
.sdram_ba (DRAM_BA),
.sdram_cas_n (DRAM_CAS_N),
.sdram_cke (DRAM_CKE),
.sdram_cs_n (DRAM_CS_N),
.sdram_dq (DRAM_DQ),
.sdram_dqm (DRAM_DQM),
.sdram_ras_n (DRAM_RAS_N),
.sdram_we_n (DRAM_WE_N),
// SRAM
.sram_DQ (SRAM_DQ),
.sram_ADDR (SRAM_ADDR),
.sram_LB_N (SRAM_LB_N),
.sram_UB_N (SRAM_UB_N),
.sram_CE_N (SRAM_CE_N),
.sram_OE_N (SRAM_OE_N),
.sram_WE_N (SRAM_WE_N),
// SD Card
.sd_card_b_SD_cmd (SD_CMD),
.sd_card_b_SD_dat (SD_DAT),
.sd_card_b_SD_dat3 (SD_DAT),
.sd_card_o_SD_clock (SD_CLK),
// Flash
.flash_ADDR (FL_ADDR),
.flash_CE_N (FL_CE_N),
.flash_OE_N (FL_OE_N),
.flash_WE_N (FL_WE_N),
.flash_RST_N (FL_RESET_N),
.flash_DQ (FL_DQ),
// Red LEDs
.red_leds_export (LEDR),
// Green LEDs
.green_leds_export (LEDG),
// HEX3 HEX0
.hex3_hex0_HEX0 (HEX0),
.hex3_hex0_HEX1 (HEX1),
.hex3_hex0_HEX2 (HEX2),
.hex3_hex0_HEX3 (HEX3),
// HEX7 HEX4
.hex7_hex4_HEX4 (HEX4),
.hex7_hex4_HEX5 (HEX5),
.hex7_hex4_HEX6 (HEX6),
.hex7_hex4_HEX7 (HEX7),
// Slider switches
.slider_switches_export (SW),
// Pushbuttons
.pushbuttons_export ({KEY, 1'b1}),
// Expansion JP5
.expansion_jp5_export ({GPIO, GPIO, GPIO, GPIO}),
// PS2 Port
.ps2_port_CLK (PS2_KBCLK),
.ps2_port_DAT (PS2_KBDAT),
// PS2 Port Dual
.ps2_port_dual_CLK (PS2_MSCLK),
.ps2_port_dual_DAT (PS2_MSDAT),
// USB
.usb_INT1 (OTG_INT),
.usb_DATA (OTG_DATA),
.usb_RST_N (OTG_RST_N),
.usb_ADDR (OTG_ADDR),
.usb_CS_N (OTG_CS_N),
.usb_RD_N (OTG_OE_N),
.usb_WR_N (OTG_WE_N),
.usb_INT0 (OTG_INT),
// Serial port
.serial_port_RXD (UART_RXD),
.serial_port_TXD (UART_TXD),
// IRDA
.irda_TXD (),
.irda_RXD (IRDA_RXD),
// AV Config
.av_config_SDAT (I2C_SDAT),
.av_config_SCLK (I2C_SCLK),
// VGA Subsystem
.vga_CLK (VGA_CLK),
.vga_HS (VGA_HS),
.vga_VS (VGA_VS),
.vga_BLANK (VGA_BLANK_N),
.vga_SYNC (VGA_SYNC_N),
.vga_R (VGA_R),
.vga_G (VGA_G),
.vga_B (VGA_B),
.vga_pll_ref_clk_clk (CLOCK2_50),
.vga_pll_ref_reset_reset (~KEY),
// Audio Subsystem
.audio_pll_ref_clk_clk (CLOCK3_50),
.audio_pll_ref_reset_reset (~KEY),
.audio_clk_clk (AUD_XCK),
.audio_ADCDAT (AUD_ADCDAT),
.audio_BCLK (AUD_BCLK),
.audio_ADCLRCK (AUD_ADCLRCK),
.audio_DACLRCK (AUD_DACLRCK),
.audio_DACDAT (AUD_DACDAT),
// Character LCD 16x2
.char_lcd_DATA (LCD_DATA),
.char_lcd_ON (LCD_ON),
.char_lcd_BLON (LCD_BLON),
.char_lcd_EN (LCD_EN),
.char_lcd_RS (LCD_RS),
.char_lcd_RW (LCD_RW),
// Video In Subsystem
.video_in_TD_CLK27 (TD_CLK27),
.video_in_TD_DATA (TD_DATA),
.video_in_TD_HS (TD_HS),
.video_in_TD_VS (TD_VS),
.video_in_TD_RESET (TD_RESET_N),
.video_in_clk27_reset (~KEY),
.video_in_overflow_flag ()
endmodule
Lien copié
4 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
That top level is little more than a port map. Plus Quartus supports mixed language. So why bother re-writing it to VHDL?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- That top level is little more than a port map. Plus Quartus supports mixed language. So why bother re-writing it to VHDL? --- Quote End --- As I said, I want to edit the given verilog. I could add a VHDL file that has a DE2_115_Media_Computer component but i'd rather not retype all those inputs and outputs to VHDL since that would take a long time. I was just wondering if someone else has already converted this or if there is an automated way to convert verilog to VHDL. If someone has a DE2_115_Media_Computer component with a port map and an entity that'd be great too.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
If you dont find it - then maybe its a good time to learn verilog. If you already know VHDL then Verilog is pretty easy to understand and write.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
For people who may have the same issue, I've added a port map from the verilog file to my VHDL file.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
