Decision scheme
Hi ,
I design decision scheme in order to determine whether the signal i '0' or '1' from group of 4 bits and then the output signal of the scheme change respectively .
for some reason the output signal Des_out is persistently '0' .
The VHDL code is :
--process - decision scheme '0' or '1'
process (ResetP)
variable score : integer range 1 to 4;
begin
score := 1 ;
if ( resetP = '1' ) then
Des_out <='0';
elsif ( clk_100M'event and clk_100M='1' ) then
for ind in 0 to 3 loop
if hlp(ind)='1' then
score := score + 1;
end if ;
end loop ;
if (score > 2) then
Des_out <= '1';
else
Des_out <= '0';
end if ;
end if ;
end process;
what is wrong in the design ?why does Des_out is consistently '0' ?
does the design have to be depend in the clock event or it will change for every change in the group of 4 bits ?
how can i watch at variable score and ind during the simulation ?
Visio file attached - look at Desicion scheme (the rest is at other process) .
wave photo attached - Des_out = '0'
Hi odedidush again.
¿Des_out goes '1' when at least one input is active? I suggest you put the decision code outside if(clk'event and... branch.
no , Des_out goes '1' when the majority at group of 4 bits is '1' ,
F.E :
0000 - Des_out ='0'
0010 - Des_out ='0'
0110 - Des_out ='0'
0111 - Des_out ='1'
1111 - Des_out ='1'
A majority circuit. Ok. Write another process without any clock.
i wrote with and without clock and Des_out is consistently '0' ...
Please post the code.
are you having problems in simulation or on the real chip? have you got a testbench? does the RTL diagram look like you expected (Im a bit worried the for loop wont be making the logic you want).
Hi, i have problems in the Model Sim simulator ; i didn't burn it on the chip yet .
i don't use quartos to weite the code , i write at notepad ++ so i don't synthesize it and see RTL diagram .
the code without clock :
process (ResetP)
begin
score := 1 ;
Des_out <='0';
else if (reserP ='0' ) then
score := score + 1;
end if ;
end loop ;
if (score > 2) then
Des_out <= '1';
else
Des_out <= '0';
end if ;
end if ;
end process;
do i need to write it differently ? without for statement ?
please post the whole coide, and the waveform, and the testbench
i attach the all project files include Test Bench .
First Part of files ->
Second Part of files ->
It takes time to see the whole code but I insist on majority circuit is a combinational one. An alternative vhdl is:
Des_Out <= '0' when ( hlp = "0000" ) else
'0' when ( hlp = "0001" ) else
'0' when ( hlp = "0010" ) else
'0' when ( hlp = "0011" ) else
'0' when ( hlp = "0101" ) else
'0' when ( hlp = "0110" ) else
'1' when ( hlp = "0111" ) else
You don't need any process nor variables. It's a brute force method but it works. It's the copy of the truth table of majority circuit on the code.
I post a code with variables and a pure combinational majority circuit. The testbench shows "test_dataout" goes high after few clocks.
--- Quote Start ---
--- Quote End ---
thanks bertulus , you help me a lot .
