17267 Discussions
Design Verilog coding for 8-bit accumulator
cym
I have been trying to do the 8-bit accumulator as the picture attached below but can't get the desire waveform. Can anyone help me? Below are the Verilog HDL coding I had done :
module ripple_add(a, b, s, cout);
	input [7:0] a,b;
	output [7:0] s;
	output cout;
	wire c1, c2, c3, c4, c5, c6, c7;
	fulladd fa0(a[0], b[0], 0, s[0], c1);
	fulladd fa1(a[1], b[1], c1, s[1], c2);
	fulladd fa2(a[2], b[2], c2, s[2], c3);
	fulladd fa3(a[3], b[3], c3, s[3], c4);
	fulladd fa4(a[4], b[4], c4, s[4], c5);
	fulladd fa5(a[5], b[5], c5, s[5], c6);
	fulladd fa6(a[6], b[6], c6, s[6], c7);
	fulladd fa7(a[7], b[7], c7, s[7], cout);
endmodule
module acc (a, sum ,overflow, clk, carry);
 input [7:0] a;
 input clk;
 output reg overflow;
 output wire carry;
 output wire [7:0] sum;
 reg d1,d2,b;
 reg [7:0]r1,r2;
ripple_add add(.a(a),.b(r2));
assign {carry,sum} = a+r2;
always @(posedge clk)
begin
    if (sum==a)
	 overflow = 0;
	 else
	 overflow =1;
	 end
 always@(posedge clk )
 begin
r1=a;
r2=sum;
d1<=overflow;
d2<=carry;
end
endmodule
 Thanks a lot if anyone willing to help me on this.
KhaiChein_Y_Intel
fulladd is missing. Could you share the full design QAR and testbench for investigation? To generate the QAR file, click on Project > Archive Project
KhaiY
cym
Here is the QAR file. I have provided a full picture and requirements in the picture also.
if there is still can't find the fulladd, here is the code for it:
module fulladd(a, b, cin, s, cout);
input a, b, cin;
output s, cout;
assign s = a ^ b ^ cin;
assign cout = ((a ^ b) & cin) | (a & b);
endmodule
 I didn't do any testbench for this design. But this is the waveform I got.
KhaiChein_Y_Intel
You may find the acc.qar attached. Do let me know if this is not the intended design.
KhaiY
KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
