17264 Discussions
Design using schematic
Hi guys.
I have problem with my design. I have created my design using Megawizard plugin. But I am confused right now. Do we need to set clock and clken for my lpm_add_sub? here is my design. Your kindness helping me very appreciated.
Typically yes, unless you had disabled them like in the upper lpm_add_sub0
Since you have enable the clock ports, the functionality of the module will be sync'ed with the clock. If you does not feed any clock to the module, it will not function as expected.
Without a clock, it will do nothing. If you dont want a clock you need to geneate the core with no clock (pipeline = 0)
The clock enable can be connected to '1'
