17256 Discussions
Differential CLK input handle
kikoss
New Contributor II
Hello
I have a a differential clk come in to FPGA agilex7 F series
Want to use it as a single clk to the design
Iam using quartus 24 .1 pro
Which good practice is recommended ?
i see on a design a use of ALTDDIO_IN primitive . is this recomended  ? is it still relevant for quartus 24 ?
Thx
Kikoss
FvM
yes. Same procedure for other differential in- and outputs.
AqidAyman_Intel
May I know what did you need to use a single ended clock in your design instead of differential clock?
kikoss
New Contributor II
Hi
To be clearer , what i meant, is that i have a differential clk that comes into the fpga , from an adc converter
I want to use this clock for the ALT_LVDS ip , and this IP is able to receive only single ended clk  as we see here
How to handle that in quartus ?
Thx
FvM
input and output ports of design modules and top level interface always appear as single ended signal, except for rarely used special differential IO low-level primitives. You make the port a differential in- or output by assigning a differential IO standard (e.g. LVDS) in pin planner or assignment editor to it.
kikoss
New Contributor II
Yes but suppose ,  I have on TOP level , clkin_p , clkin_n  , and suppose i assign them to external pins
What to connect to inclock  port of the adc contoller ?
Thx
FvM
Why are you using separate clkin_p and clkin_n pins in the port definition? The usual way is to have a single ended logical port and assign a differential pin pair. You can use an ALT_INBUF_DIFF low level primitive to do the translation but it has no benefit for standard differential inputs.
kikoss
New Contributor II
i will explain why using separate ports
i have an ADC convertere that send data to the FPGA
it interface from the ADC to the FPGA is . clk , and data as on the image
As you see the DCO CLK that go the FPGA is a differential pair .
So how to handle this differential pair on FPGA ? The ALT_INBUF_DIFF primitive is supported only for Stratix® III and Cyclone® III devices . and Iam not using those devices
THX
FvM
I know how an ADC LDVS interface looks like, I'm working with it since 15 years or so. Here's an example how I configure clock and data interface for AD9222, in this case I'm using FCO rather than DCO and a PLL to generate bit clock.
top entity port definition
   ADC_CLK     : OUT STD_LOGIC;
   ADC_FCO    :  IN STD_LOGIC;
   ADC_LVD     : IN STD_LOGIC_VECTOR(1 TO 8);
assigned IO standards
  set_instance_assignment -name IO_STANDARD LVDS -to ADC_LVD*
  set_instance_assignment -name IO_STANDARD LVDS -to ADC_FCO
  set_instance_assignment -name IO_STANDARD LVDS -to ADC_LCLK
If you review Intel documents, you'll realize that this is the suggested way to implement differential in- and outputs.
FvM
Forgot to mention that single-ended port signal is assigned to positive pin of the differential pair, corresponding negative pin is assigned by fitter automatically.
kikoss
New Contributor II
Hello
OK if i understand you correctly
  • you declare 1 port CLK on top level  RTL module - let say FCO_CLK  (even if its differential from the ADC)
  • use this port on the RTL , for PLL input etc..
  • assign FCO_CLK   only to  P leg on assignment editor (and not assigning at all N leg)
  • let the fitter do the job for N leg
Thats rigth ?
THX
FvM
kikoss
New Contributor II
Yes , in the example i provide , I agree that this procedure should be applied to the FCO CLK  or for the DCO CLK's that are connected to the inclock port (see figure)
But , for the rx_in_p and rx_in_n,  the ALT LVDS ip called adc_controller (in the figure above) handle differential P and N legs ... so I understand that we must declare P and N as well on the RTL as separate ports . rigth ?
THX
AqidAyman_Intel
I wish to follow up with you. Did your issue is resolved after following the suggestion by @FvM?
Aqid
kikoss
New Contributor II
Hello Yes its ok
THX
AqidAyman_Intel
Thank you for your confirmation. I’m glad that the issue has been addressed. If you have a new question and new more support, feel free to log in to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you.
