Reason for the question, is purchased Pro edition for A10 support but need to also implement Cyclone V designs; I would assume Pro would give me access to all the features of Prime, to include all legacy devices?
I think you mean "Standard" instead of "Prime" (all 3 editions (Lite, Standard, Pro) are called Quartus Prime).
I believe a Pro license file will work with Standard. The easiest thing to do is to download and install Standard and try pointing to your license file.
#iwork4intel
I already know that Pro does not support C5, what I need to know is, with a license for Pro, does it also include Prime, in order to support Cv and other legacy devices? please quit answering with the pad answer above, and let me know if a another license is required, or if the single Pro license entitlement, also allows to use Prime simultaneously with one pro license entitlement.
regards
#iwork4intel
Thanks so much, this is kind of what I thought, but had to be sure; I will let the end customer know and I do appreciate your quick turnaround/response.
