17267 Discussions
I am getting the following compile errors while compiling a CAM Memory project (Schematic files) in Quartus prime 18.1, as follows: Error(16185): Can't elaborate user hierarchy "inst" Error(16186): Can't elaborate top-level user hierarchy
aabum
  • Cyclone 10GX device were used in this project
sstrell
Without seeing the design or code, it's impossible to figure out why you are getting a compilation error. Can you provide anything?
#iwork4intel
JoanneSinY_L_Intel
Hi, May I know any update or shall I consider to be case closed? Thanks Joanne
aabum
Thanks, I solved the problem, by change the device family.
