17268 Discussions
Does Quartus Pro edition entitlement also include access to Prime?
WWals
Reason for the question, is purchased Pro edition for A10 support but need to also implement Cyclone V designs;   I would assume Pro would give me access to all the features of Prime, to include all legacy devices?​
sstrell
I think you mean "Standard" instead of "Prime" (all 3 editions (Lite, Standard, Pro) are called Quartus Prime).
I believe a Pro license file will work with Standard. The easiest thing to do is to download and install Standard and try pointing to your license file.
#iwork4intel
AR_A_Intel
Hello Welcome to INTEL forum. No, A10 device is only supported in Quartus Pro and do not support Cyclone v designs. For more can refer here https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf
WWals
​I already know that Pro does not support C5,   what I need to know is,  with a license for Pro,  does it also include Prime, in order to support Cv and other legacy devices?   please quit answering with the pad answer above, and let me know if a another license is required,  or if the single Pro license entitlement, also allows to use Prime simultaneously with one pro license entitlement.
regards
sstrell
#iwork4intel
WWals
​Thanks so much,  this is kind of what I thought, but had to be sure;  I will let the end customer know and I do appreciate your quick turnaround/response.
