17267 Discussions
Downloading ELF Process failed when executing from flash
I am using Eclipse to program my Nios on a Max10 FPGA. When I run the Nios code from the RAM everything works fine. Now I changed everything so that the code would execute directly from the flash (on-chip). I set all settings as described here:
https://www.altera.com/en_us/pdfs/literature/an/an730.pdf
I used Option 1a
Now if I try to run/debug the code directly out of Eclipse I get "Downloading ELF Process failed".
Console says:
--- Quote Start ---
Using cable "USB-BlasterII [USB-1]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x00481028: verified
Initializing CPU cache (if present)
OK
Downloading 00200000 ( 0%)
Downloading 00210000 (70%)
Downloaded 92KB in 0.1s
Verifying 00200000 ( 0%)
Verify failed between address 0x200000 and 0x20FFFF
Leaving target processor paused
--- Quote End ---
Attached is my setup.
I programmed the Nios code with a *.pof to the device and this also works fine.
Is it even possible to run/debug code directly from Eclipse?
Best Regards
Usually that would be due to missing timing constraints, but I see you are connected to on-chip rather than off-chip flash.
I it seems you assigned the memory region in the BSP editor, but did you change the physical wiring in Qsys to allow Nios II instruction/data master to access the on-chip flash? (I can't see the Qsys diagram...resolution too small...)
SDevaux
I have the same problem, everything go right when I program via Quartus Programmer in pof.
I can run it from SBT, but if I change something in my C Code, I have to rebuild pof, program UFM and then I can launch it from SBT Run "NiosII hardware".
Seems that SBT can have access to UFM in write mode.
did you have an ansewer from Intel?
