17255 Discussions
EPCS16 write one byte more than once
I'm trying to use the EPCS16 as storage memory for few bytes.
The configuration is: Use Mega Function ALTASMI_PARALLEL without NIOS.
I managed to read and write one byte the first time.
When I try to rewrite in the same address the data keep the same.
It is known any single byte write limitation?
I'm using Quartus 11.0.
Manpsilva
Review the serial flash datasheet: After erasing a 512 kbit sector, you can only change data bits from '1' to '0' when wrring one or multiple bytes with a page program command.
Thanks, that explains a lot!
But I can't find on the Datasheet I have...
M
