I'm trying to use the EPCS16 as storage memory for few bytes. The configuration is: Use Mega Function ALTASMI_PARALLEL without NIOS. I managed to read and write one byte the first time. When I try to rewrite in the same address the data keep the same. It is known any single byte write limitation? I'm using Quartus 11.0. Best Regards, ManpsilvaLink Copied
Review the serial flash datasheet: After erasing a 512 kbit sector, you can only change data bits from '1' to '0' when wrring one or multiple bytes with a page program command.
Thanks, that explains a lot!
But I can't find on the Datasheet I have... Best Regards, M
