17252 Discussões
Easiest Testbench for my VHDL code (multiplication)
Colaborador honorário II
6.900 Visualizações
Hello there. Is there somebody who can make testbench from my vhdl code? It is multiplication of 2 integers, which are n-1 downto 0.. n=16. Thanks a lot..
library IEEE;use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.ALL; entity MultExample is Generic ( n : natural := 16); Port (A,B : in std_logic_vector(n-1 downto 0); Q : out std_logic_vector(n*2-1 downto 0); end MultExample; architecture Behavioral of MultExample is BEGIN Q <= std_logic_vector(signed(A) * signed(B)); end architecture Behavioral;
12 Respostas
4.776 Visualizações
Thanks a lot for these files.. But i don't know what to write to UUT.. It is empty and i need to put values there.
4.776 Visualizações
--- Quote Start ---
--- Quote End ---
option 1: don't write any testbench. Just use mult module with inputs initialised to values of your choice and check output on waveform.
option 2: write testbench as counting sequences to drive the inputs.
option 3: don't do anything and trust the mult as we do. once your project is mature you can testbench your whole project
4.776 Visualizações
I need testbench.. It is school homework but i don't know how to edit it.
4.776 Visualizações
Hi
Have you tried option 1??
Learn to write test-bench google it.
http://eng.umb.edu/~cuckov/classes/engin341/lectures/l02%20-%20vhdl%20-%20dataflow%20and%20structural%20modeling%20and%20testbenches.pdf
--ONE OF THE WAY OF WRITING TB IS SHOWN YOU CAN USE LOOPS TO TEST ALL THE CASE stimulus: process begin a<="0101"; b<="0101"; wait for 20ns; a<="1111"; b<="1111"; wait; end process;
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
4.776 Visualizações
--- Quote Start ---
Hi
Anand Raj Shankar
--- Quote End ---
Hello, i have tried with Q too or i dont need to? I got errors:
# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(96): near "'": syntax error# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(97): near "'": syntax error# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(98): near "'": syntax error# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(100): near "'": syntax error# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(104): VHDL Compiler exiting# ** Error: D:/altera/13.0sp1/modelsim_ase/win32aloem/vcom failed.
This is my code for test bench:
library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_Std.all; entity nasobenie_tb is generic ( DATA_WIDTH : natural := 4 ); end; architecture bench of nasobenie_tb is component nasobenie generic ( DATA_WIDTH : natural := 4 ); port ( a : in signed ((DATA_WIDTH-1) downto 0); b : in signed ((DATA_WIDTH-1) downto 0); q : out signed ((2*DATA_WIDTH-1) downto 0) ); end component; signal a: signed ((DATA_WIDTH-1) downto 0); signal b: signed ((DATA_WIDTH-1) downto 0); signal q: signed ((2*DATA_WIDTH-1) downto 0) ; begin -- Vlozenie hodnot pre parameter generic !! uut: nasobenie generic map ( DATA_WIDTH => DATA_WIDTH ) port map ( a => a, b => b, q => q ); stimulus: process begin a <= '0000'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '0001'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '0010'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '0011'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '0100'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '0101'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '0110'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '0111'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '1000'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '1001'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '1010'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '1011'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '1100'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '1101'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); a <= '1111'; b <= '0000'; wait for 10 ns; assert(q = '00000000'); end process; --koniec opisu procesov end bench; --koniec opisu architektury tb configuration cfg_bench of nasobenie_tb is --konfiguracia test bench entity for bench --cyklus je prazdny, nema ziadnu specificku funkciu v nasom pripade end for; --koniec cyklu end cfg_bench; --koniec opisu konfiguracie
4.776 Visualizações
for strings (like arrays) you should be using double quotes, not single quotes.
Also, with your asserts, you are not reporting, so I doubt you will get a meaningful message.
4.776 Visualizações
Thanks for help. One more problem:
# ** Fatal: (vsim-3420) Array lengths do not match. Left is 4 (3 downto 0). Right is 2 (3 downto 2). # Time: 0 ps Iteration: 0 Process: /nasobenie_tb/stimulus File: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd # Fatal error in Process stimulus at D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd line 41 # # HDL call sequence: # Stopped at D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd 41 Process stimulus #
I don't know how to fix that.. I am using 4 downto 2 is it bad? I have 2 bits and after multiplication i got 4 bits or I am wrong? Thanks.
4.776 Visualizações
I think the error is fairly self explanitory.
wherever the error is, the widths do not match. The left side requires 4 bits, but you're only assigning 2
4.776 Visualizações
It is multiplication.. When i multiply 2 bits and 2 bits number, result is 4 bits or i am wrong?
How to solve it? Any solution? Can you tell me which one change and to what value..
4.776 Visualizações
Yes, multiplying 2 bit numbers gives a 4 bit result.
The error you posted is not in the code you posted, so I have no idea how to fix it.
4.776 Visualizações
I will try to send there both codes..
nasobenie.VHD:
-- Quartus Prime VHDL Template -- Signed Multiply library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity nasobenie is generic ( DATA_WIDTH : natural := 8 ); port ( a : in signed ((DATA_WIDTH-1) downto 0); b : in signed ((DATA_WIDTH-1) downto 0); q : out signed ((2*DATA_WIDTH-1) downto 0) ); end entity; architecture rtl of nasobenie is begin q <= a * b; end rtl;
And now nasobenie_tb.vhd
library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_Std.all; entity nasobenie_tb is generic ( DATA_WIDTH : natural := 4 ); end; architecture bench of nasobenie_tb is component nasobenie generic ( DATA_WIDTH : natural := 2 ); port ( a : in signed ((DATA_WIDTH-1) downto 0); b : in signed ((DATA_WIDTH-1) downto 0); q : out signed ((2*DATA_WIDTH-1) downto 0) ); end component; signal a: signed ((DATA_WIDTH-1) downto 0); signal b: signed ((DATA_WIDTH-1) downto 0); signal q: signed ((2*DATA_WIDTH-1) downto 0) ; begin -- Vlozenie hodnot pre parameter generic !! uut: nasobenie generic map ( DATA_WIDTH => DATA_WIDTH ) port map ( a => a, b => b, q => q ); stimulus: process begin a <= "00"; b <= "00"; wait for 10 ns; a <= "00"; b <= "01"; wait for 10 ns; a <= "00"; b <= "10"; wait for 10 ns; a <= "00"; b <= "11"; wait for 10 ns; a <= "01"; b <= "00"; wait for 10 ns; a <= "01"; b <= "01"; wait for 10 ns; a <= "01"; b <= "10"; wait for 10 ns; a <= "01"; b <= "11"; wait for 10 ns; a <= "10"; b <= "00"; wait for 10 ns; a <= "10"; b <= "01"; wait for 10 ns; a <= "10"; b <= "10"; wait for 10 ns; a <= "10"; b <= "11"; wait for 10 ns; a <= "11"; b <= "00"; wait for 10 ns; a <= "11"; b <= "01"; wait for 10 ns; a <= "11"; b <= "10"; wait for 10 ns; a <= "11"; b <= "11"; wait for 10 ns; end process; --koniec opisu procesov end bench; --koniec opisu architektury tb configuration cfg_bench of nasobenie_tb is --konfiguracia test bench entity for bench --cyklus je prazdny, nema ziadnu specificku funkciu v nasom pripade end for; --koniec cyklu end cfg_bench; --koniec opisu konfiguracie
4.776 Visualizações
The error you have posted doesnt appear to be for this code.
I suggest deleting the configuration from the code.
Responder
