17263 Discussions
Eclipse for Nios II Unrecognized Func Def
road_runner
The problem and steps I've taken is outlined in the following post:
https://forums.freertos.org/t/definitions-port-c-alt-ic-irq-disable-enable/18579
Despite this being a topic in a previous discussion board (https://community.intel.com/t5/Intel-Quartus-Prime-Software/Why-I-can-not-find-the-alt-irq-enable-function-in-HAL-src/td-p/174843) the fix applied does not work for me. The program is simply the standard FreeRTOS build and although the function definition is there, the compiler keeps giving me a makefile 1033 error and "undefined reference to alt_ic_irq_enable/disable" errors. And the definition is in a file that's been included. I'm not sure where to go from here to further troubleshoot the issue.
Thanks in advance!
wwanalim_intel
Based on the forum link you attached, it seems you already found the solution. Do you able to solve it already?
wwanalim_intel
Greetings and welcome to Intel's forum.
Please give me some time to check on this issue and will get back to you with the update.
Thank you.
Fathulnaim
wwanalim_intel
road_runner
I apologize for not responding to this thread sooner. Yes, the solution worked for me. Thanks!
wwanalim_intel
It seems the issue already been solved in this forum below.
wwanalim_intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
