17257 Discussions
Encryption of Intel's FPGA IP
Armen
Having problem to encrypt FPGA's IP using Quartus version 19.1 on Cyclone 10GX: 10CX150YU484I6G part. need help as we shipping IP overseas.
I attached error message during Encryption procedure. Seems device i snot supported. Anything I did wrong, any workarounds or suggestions.
Armen
sstrell
The PFG is set to Cyclone 10 LP instead of GX.  Is that the issue?
Armen
Thanks for the first reply, sstrell. I had no chance to choose GX part. Is it possible 10GX part is not supported at all?
Anybody who successfully encrypted POF for 10GX part?
Armen
sstrell
I don't know if you've read this guide, but this has info about encryption:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10gx-51003.pdf
You can't encrypt and compress at the same time if that is applicable here.
Armen
Hi there , I know my problem. The issue was with the length of the key. There is no message telling that key is not 64 byte long. That's the reason, generate button was always greyed in Encryption dialog box.
Once, I got enough characters, Generate button activated and I was able to generate encrypted POF file
Amen
SyafieqS
Hi Avardape,
Any update on this or other concern?
Armen
Hi, I managed to get encrypted pof file. However, when I program encrypted pof file I do not see FPGA is working as intended.  Not clear how the key generated should be used to unlock encrypted file at customer site.
Any advice is highly appreciated
Armen
SyafieqS
Hi Avardape,
Glad to hear that. What is not working? Do you see any hardware incorrect functionality or what? If yes, maybe you can signaltap your hardware and see where goes wrong.
