Hello.
I am trying to make a simple UP/DOWN counter and I am fairly new to VHDL. I keep getting the following error "Error (10327): VHDL error at Counter.vhd(51): can't determine definition of operator ""+"" -- found 0 possible definitions" My code is
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity counter is
generic
startnum : natural := 0;
N : natural := 16
port
--Inputs
EN : in std_logic;
synchr : in std_logic;
asyncr : in std_logic;
dir : in std_logic; --0 for count down 1 for count up.
clk : in std_logic;
--Outputs
Y : out natural range startnum to n-1
end entity;
architecture counter_v1 of counter is
signal cntconst : integer;
begin
process (dir) --dir in sensitivity list as when this changes we want this process to run.
begin
if (dir = '0') then
cntconst <= -1; --this will count down when added onto to the counter value
end if;
if (dir = '1') then
cntconst <= 1;
end if;
end process;
process (EN, synchr, asyncr, clk)
variable notsurewhyitworkswiththis : integer range startnum to n-1; --I tried to just use y but for some reason it won't allow that.
begin
if (en = '0') then
else
if (asyncr = '1') then
notsurewhyitworkswiththis := 0;
else
if (clk = '1') then
if (synchr = '1') then
end if;
end if;
end if;
if (cntconst < n-1) then
if (dir = '1') then
notsurewhyitworkswiththis := notsurewhyitworkswiththis + dir;
end if;
end if;
if (cntconst > startnum) then
if (dir = '0') then
end if;
end if;
end if;
y <= cntconst;
end process;
end counter_v1;
It is starting tio get a bit annoying now, I have tried loads of things I read online but to no avail. Any help would be hugely appreciated.
dir is a std_logic, and therefore not a number, and notsurewhyitworkswiththis is an integer. The types are incompatible.
I am being a absolute **** and adding the wrong damn thing. It's meant to be cntconst. Thanks .
Just to add, your process is not a clocked process. It is using clk as a transparent latch enable. I suggest following the correct template:
process(clk, reset)
begin
if reset = '1' then
--async reset here
elsif rising_edge(clk) then
--sync stuff goes here
end if;
end process;
Thanks, that makes sense.
It compiled and I did the VWF of it. It has decided not to count...it just stays at 0001 which strikes me as odd as it should be a 16 bit number. Is there anything obvious to you as to why it wouldn't count?- Mark as New
Open the RTL Viewer to see what Quartus inferred from your code. Post the corrected code. In the original one, the counter enable was used as an asynchronous signal. It should be:
if( clk'event and... if( en = '1' ) then count <= count + 1; The next state logic was outside the rising edge if. But you may change it. Again, post the code.- Mark as New
I made some changes to it, it is slightly neater now but now it won't compile because it is expecting a bracket or something...error 10500
library ieee;
entity counter is
generic
N : natural := 16
port
--Inputs
EN : in std_logic;
clk : in std_logic;
--Outputs
end entity;
begin
begin
if (dir = '0') then
end if;
if (dir = '1') then
cntconst <= 1;
end if;
end process;
process (asyncr, clk)
begin
if(asyncr = '1') then
y < = 0;
elsif(rising_edge(clk)) then
if(en = '1') then
if(dir = '1') then
if(y < y'high) then
y < = y + 1;
end if;
else
if(y > y'low) then
y <= y - 1;
end if;
end if;
end if;
end if;
end process;
end counter_v1;
if(y < y'high) then
y < = y + 1; end if; else if(y > y'low) then y <= y - 1; end if; Are y'high and y'low constants? I don't rembember if you can use ' in a signal or constant name ( y'high and y'low ). Replace them by _.- Mark as New
--- Quote Start --- now it won't compile because it is expecting a bracket or something...error 10500 --- Quote End --- It's really worth to read error messages thoroughly, also reviewing the referred code line. --- Quote Start --- Error (10500): VHDL syntax error at counter.vhd(39) near text "<"; expecting "(", or "'", or "." --- Quote End ---
y < = 0;
Did you get an idea why the parser sees a "<" token where you seems to write a "<="? If not, delete and rewrite the line, preferably thinking about required VHDL syntax. After fixing this trivial error, Quartus will possibly complain about reading an out signal.
Topic Options
